Custom Chip?
Old Feb 3, 2009 | 09:33 PM
engle1147's Avatar
engle1147
Default Custom Chip?
I want to get a ECM chip/calpac for an 1989 350ci / auto. Whom do you recommend I give my business too?
Car is mostly stock and has only minor mods and I have no imediate engine upgrade plans.
Mods include:
No Cats -- 2.25 straight pipes with Borla Mufflers
Cut lid with K&N filter
Ported heads and intake
21# Bosh type II
Cooling fan relay has been grounded to run while the key is "on"
*** I also want the chip modified so that it doesn't use the injector enable signal from the VATS***
Old Feb 4, 2009 | 10:15 PM
engle1147's Avatar
engle1147
Ok, thanks for all the responses, it made my choice an easy one. I'm going to go with PCM4<. I'll let you guys that responded know how it works out. Thanks for the input.
Old Feb 6, 2009 | 08:01 PM
engle1147's Avatar
engle1147
So I ordered the chip (piggy backs the stock chip) on Wenesday evening and it arrived today (Friday). Install was a piece of cake once I removed the ECM case cover. Got the changes I was looking for and the car is running great. Thanks A.A.
To Custom Chip?
