tpi porting
Old Feb 19, 2009 | 01:12 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Originally Posted by 65Z01
Not sure what is the question here??
He was asking if the intake runner on 113 heads takes a [FelPro] 1204 intake gasket. And, it does. (Unless ported bigger of course!)
FYI: 1205 isn't a lot bigger which means it's easy to port out to a 1205 too.
gp
Old Feb 19, 2009 | 05:54 PM
ekess744's Avatar
ekess744
Originally Posted by GREGGPENN
That is interesting....
Hey. Were your gaskets like "petrified"? My runner gaskets were SOOOO hard and glued to the runners/base, I could not believe it. Almost like they were epoxy'd
I've never seen anything like it, but I've also never pulled a car apart that's this old.
It was never the entire gasket that gave me any trouble, just sections of it. Basically 3/4 of the gasket material came off easily and the other 1/4 fit the discription of expoy'd.
Old Mar 6, 2009 | 01:47 PM
ekess744's Avatar
ekess744
I am getting close to wrapping un the grinding and I have a couple new questions
My manifold base has small holes in the runners. How do I make sure I have gotten all of the shavings out of there?
I am considering pressure washing the base and I am guessing the sensors need to removed. What kind of sealant is used on them for the reinstallation?
Old Mar 6, 2009 | 02:42 PM
tmichaud's Avatar
tmichaud
wow, this sounds all to familiar.
I am going through this exact same thing, however I did pull the trigger on the FIRST intake. (sitting in my garage now waiting for me to polish it).
It started with wanting a bit more power - so start with intake....my valve seals are leaking so need seals and springs....got the bigger intake need to do more exhaust ...pricing headers.... hmmm intake and exhaust off - touching the heads - maybe pull them and pocket port, port match, thinner gasket for 10:1 - have valves back cut.... hmmm.. intake and heads off, just cam across the crane cam and lifters for dirt cheap....
I am not sure If I will ever get it back on the road once I start!!!!
I am very interested in the head porting discussion here though..
Old Mar 6, 2009 | 10:12 PM
ekess744's Avatar
ekess744
I need to replace the sensor underneath and at the back of the plenum (IAT?) Is this the right part?
http://www.bmotorsports.com/shop/pro...roducts_id/398
