Transmission pump seal leaking
Old Feb 6, 2009 | 04:19 PM
mb87's Avatar
mb87
Default Transmission pump seal leaking
I have a leak around the front pump where its bolted to the tranny. Its not leaking at the shaft seal. Is there gasket or o-ring that needs replacing or will tightening the bolts (which I haven't tried yet) take care of the problems?
Old Feb 6, 2009 | 04:38 PM
my83432's Avatar
my83432
You can try the bolts around the pump but if the gasket is bad it will have to be replaced. So yes there is a gasket. The trans will need to be pulled to do it. If you going to do this change the front seal as well.
