91 Scanning
I would like to scan using tuner pro or scanner pro. However the definition file i have is pretty limited in terms of looking at the a/c system voltages and pressures.
Is there anyone with this information for a definition file that can be used on a 91 vette? or how can i add this info into the existing def?
Thanks!
Thanks!
I don't know of a def file that will read that with tuner pro. I've got Tuner Pro RT and it does not show any items involving the AC. If you want to read the pressures you'll need to get a set of gauges or take it to good shop.
Yea i finally fixed my a/c as only one fan was coming on when i turned on the ac, i unplugged the pressure sensor, and now both fans come on right away
Have another question for you though, I finally got tuner pro and datamaster to work with the available information, but once i start the connection on my laptop, the car runs really rough and stumbles, and flashes the service engine soon light. Can linking up to a computer really cause the ecm to mess up?
Cheers
