???Gas Gauge???
Old Feb 10, 2009 | 10:56 PM
stjs45's Avatar
stjs45
Default ???Gas Gauge???
Hey there. Im a new Corvette owner as today. I got a 94 vette that the gas meter doesnt read anymore that a quater. It can easly go up as down to reserve. I also got light for about two minuters that said "check gauges". Some one said it was pretty common. What is it? How can i fix it? and how hard is it? Thanx
Old Feb 10, 2009 | 11:18 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Welcome and congrats on your new-to-you Corvette...
We've had our 94 for awhile and you'll love it, so best of luck...
regarding the gas-gauge, it is a common problem on all the C4's --
The problem is the gauge has a corrosion problem which can sometimes be cleaned (caused by increased sulfer in gas).
The gauge is relatively easy to remove (through the fill door) but will require a new gasket to re-install.
Do a search. Also there should be a write-up in the 'tech' section.
Old Feb 10, 2009 | 11:23 PM
tim32920's Avatar
tim32920
If that doesnt work you will have to order a new sending unit which is easy to install as well.
I just got a new fuel sending unit from corvette central for 199.00.
Old Feb 11, 2009 | 11:48 AM
stjs45's Avatar
stjs45
I went to corvette central and i saw it for $310. Part # 364458 . Is this it?
Old Feb 11, 2009 | 12:56 PM
Firevette's Avatar
Firevette
Cruise-In X Veteran
http://www.corvetterecycling.com/198...p/25027510.htm
Forum vendor Corvette Recycling has them. Brand new GM NOS for $199. I purchased from them before, great prices and great service.
Old Feb 11, 2009 | 07:35 PM
guido7834's Avatar
guido7834
My gauge on my 87 hasn't worked in years. You get used to it. Just keep track of your mileage and spend the cash on other goodies!
Old Feb 11, 2009 | 10:33 PM
tim32920's Avatar
tim32920
OOPS
Sorry my bad it was corvette recycling
Old Feb 11, 2009 | 10:59 PM
F1Fan's Avatar
F1Fan
I've heard of folks having been successful in flipping the rheostat? around and using the other side of it and having it work accurately again.
Old Feb 11, 2009 | 11:27 PM
stjs45's Avatar
stjs45
You dont need to drop the fuel tank or anything right? Its just some screws and some disconecting hose and sensor wire and then just reconecting everything back correct?
Old Feb 12, 2009 | 06:32 AM
tim32920's Avatar
tim32920
Correct just take the 4 torx screws out of the fuel door than the rubber around the fuel neck and then you'll see 8 or 10-10 mm bolts take them out undo the 3 hoses and lift it out carefully and unplug the wires for the sending unit and fuel tank,take off the fuel pump and put it on your new unit and than put it all back together you can do this in no time really it is a simple job.
Old Feb 12, 2009 | 10:27 AM
Da Mail Man's Avatar
Da Mail Man
........the "fix" is not all that hard!....i did it to mine 5 years ago and works fine!....it may not require replacement at all!
Old Feb 27, 2009 | 03:33 PM
4indog's Avatar
4indog
Originally Posted by Da Mail Man
........the "fix" is not all that hard!....i did it to mine 5 years ago and works fine!....whomever wants the fix, send me a pm with your e-mail address and i will mail you a word doc attachment...it may not require replacement at all!
Gas gauge is stuck at full. Please send word doc with fix.
Thx.
4indog@msn.com
Old Feb 27, 2009 | 04:06 PM
Da Mail Man
Thx.
4indog@msn.com
..didn't you e-mail me requesting this and didn't i just send this to you a few weeks ago?....
To ???Gas Gauge???
