u joint question
Old Jan 23, 2002 | 09:19 PM
Pete89's Avatar
Pete89
Default u joint question
what do you preffer ,the u joints wiyh zerk fittings or without?
Old Jan 23, 2002 | 09:25 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: u joint question (Pete89)
I think the ones w/o zerks are the strongest. Spicer or Brute Force seem to get the best reviews around here. I have all Brute Force on my car and havn't had a failure yet, at least with the u-joints, hahahaaah.
Old Jan 23, 2002 | 10:18 PM
87SAM's Avatar
87SAM
I had problems trying to find joints without the zerts around town (this IS Boise Idaho :D ). I ended up getting some lifetimes from Napa. They have zerts, some funky tiny thing on the endcap, never seen that kind of thing before :confused: . I'm sure they are stronger than the "normal" zert type. First I though they could throw the balance off, but they are so small. Had my shafts balanced so it don't matter anyway. Unless I have to change u-joints again soon :eek:
Old Jan 23, 2002 | 10:32 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: u joint question (87SAM)
Those ones from NAPA are Spicers, I have them on mine.
Old Jan 23, 2002 | 10:44 PM
87SAM's Avatar
87SAM
Default Re: u joint question (Mr Mojo)
What! I was wanting Spicers in the firt place, couldn't find them but got them anyway :D :D :D
Old Jan 24, 2002 | 12:21 PM
Greg Johnson's Avatar
Greg Johnson
Friends,
I have u-joints with grease fittings all the way around. They've been on 1 1/2 years with no problems. But someone said they must be mounted correctly for greater strength. I am not sure what that meant.
Anybody know?
Gregor :seeya
Old Jan 24, 2002 | 03:22 PM
Mr Mojo's Avatar
Mr Mojo
Default Re: u joint question (Greg Johnson)
Friends,
Anybody know?
Gregor :seeya
I've heard that also and have no idea what is meant by that.
Old Jan 24, 2002 | 03:26 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Whatever you do, stay away from Brute Force, zerk or no zerk. I personally would not get one with a zerk fitting.
Old Jan 24, 2002 | 03:36 PM
SharkB4C4's Avatar
SharkB4C4
Friends,
Anybody know?
Gregor :seeya
Two of the 4 "arms" (legs?) of the u-joint apply the power, the other two receive power. For maximum strength, the u-joint should be mounted so that the hole for the zerk fitting would be compressed rather than stretched apart when power is applied.
Easier to explain with a picture, but I don't have any. (I'm also assuming the traditional zerk location at the base of arms.)
Old Jan 24, 2002 | 04:39 PM
MCPOWHITE96's Avatar
MCPOWHITE96
Default Re: u joint question (SharkInShark)
here is a REAL basic drawing showing what they mean. As you can see from the direction of rotation, the applied force will tend to compress rather than elongate the area where the zerk is located.... therefore preventing tearing the u-joint in half at the weak spot created by the drilled hole for the zerk fitting.
:cheers:
Old Jan 24, 2002 | 05:53 PM
N20LT4's Avatar
N20LT4
Default Re: u joint question (MCPOWHITE96)
That actually makes sense!!! Learn something everyday.
Old Jan 24, 2002 | 06:08 PM
Mr Mojo's Avatar
Mr Mojo
Thanks Tim for the picture, now it makes sense.
Old Jan 24, 2002 | 06:14 PM
MCPOWHITE96
I live to serve. glad it helped. someone had to draw that for me about 3 years ago for me to get it also..... :flag
Old Jan 24, 2002 | 06:20 PM
Turismo's Avatar
Turismo
I use GMB performace series U-joints. They have a lifetime warranty and are used by many OEMs including Porche. I don't mind the zerk as I can pack the u-joint with any grease of my choice (including synthetic).
Old Jan 24, 2002 | 06:24 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
And don't do a burnout in reverse :D.
Old Jan 24, 2002 | 09:57 PM
6spd89's Avatar
6spd89
Matt
Old Jan 26, 2002 | 12:33 AM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
Hee, hee.....only a hole snipe could answer a question like that ;)
Thanks, MasterChief. :cheers:
Old Jan 26, 2002 | 06:27 AM
patrick sieben's Avatar
patrick sieben
Great picture it help me understand it better. I read it in the installation maual of my u-joints the same way. The only problem I had was determining the position of the say the half shafts where the zerks are actually compressed or where they are tugged upon. The zerk turns around with the half-shaft and the yolk. I the have shaft has a downward inclination it will be different from when it has an upward inclination. For that reason I personally think using these on the half shafts isn't the best option. I personally think using them on the propeller shaft wouldn't matter because it has a fixed orientation and as we all know a little angel on them to keep the needle bearings rolling. So there I suppose the zerk can be mounted in such away that it is always compressed. On the half shafts I don't see it.
How is that for my personal theory?
cheers
Patrick :D
To u joint question
