Car blew up NEED HELP
Old Feb 14, 2009 | 11:07 AM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Originally Posted by derekguzz
its a valve that is right infront of the blank coolant tank on the passanger side. I gues it open at high rpms to push more coolant threw. Anyways it broke. I dont have to be a wrench turner to replace this thing. Its only 2 metal tightners. Never mind. Ill ask someone else. Some of you guys on here are dicks.
Thermostats are easy to replace. Just make sure to use a new gasket.
I would also flush the system and replace the hose that busted. Sounds like it got to hot, the pressure built up, and the hose couldn't withstand it anymore.
Old Feb 14, 2009 | 11:23 AM
MikeC4's Avatar
MikeC4
I blew a coolant flow restrictor on my '95, this is what you are looking for. You can just go buy a plastic hose coupler from Poop boys or autozone as a temporary fix:
another member pointed out that rockauto.com carry these:
Old Feb 14, 2009 | 11:33 AM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Everything you have described is very simple to do and if you dont feel comfortable doing you should get some help. I am sure there is someone on this forum in your area who will help.
Could be a dick though You just have to take a chance
Old Feb 14, 2009 | 11:59 PM
derekguzz's Avatar
derekguzz
well thanks for the sarcastic remarks, I don't have a tendency to do anything. I get ripped on for spelling a lot and all I try is do is ask questions. But most times I am searching for people who could use my 2 cents. But thanks guys again for helping. I have never changed a T-stat but from the help it doesn't sound hard at all. As far as the coolant, the house is fine but the plastic connector just broke. I saw the pics the one guy sent me and that one is black. Mine is like a ugly light green color and also has like a fake looking turn **** on top. Once again sorry for the delays in pics. i should have one up tomorrow morn.
Old Feb 15, 2009 | 11:46 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Personally I doubt the thermostat is bad the Flush port probably just broke. As I already stated you probably have your flow control replaced by one. It was probably leaking before it broke completely. I would peplace that first.I have neither in my current car just a coupling and the heater works just fine.
Old Feb 15, 2009 | 12:04 PM
MikeC4's Avatar
MikeC4
Sounds like someone put in an after market flow control device that allows you to manually open/close the valve. This gives you the option to shut off the flow of hot coolant during summertime(even though the diverter door should prohibit hot air from entering cabin). I also just used a hose coupler on my '95 with no problems. I have "read" that the flow control device is used in order to reduce the high coolant flow rate through the heater core at high RPM's .
Old Feb 15, 2009 | 08:29 PM
derekguzz's Avatar
derekguzz
Not normal looking? who will have one of these. If I can use something else i will....where did u guys get urs from
Old Feb 15, 2009 | 10:13 PM
MK 82's Avatar
MK 82
That is a Prestone flushing tee. The thing you call a valve is a cap. Remove it to attach a garden hose.
Old Feb 15, 2009 | 10:38 PM
derekguzz's Avatar
derekguzz
so i can just get what is pictured above my post? the black valve?
Old Feb 15, 2009 | 10:48 PM
Ryan59's Avatar
Ryan59
derekguzz That is not factory on the car. Someone put it on there to aid flushing the cooling system. You can get another one at Wall Mart or any auto supply store, or replace the hose they guy cut in half and not have to worry about it breaking again later on. You do not need one of those deals to flush the cooling system. I do not like them because it's just something else to fail and leave you stranded. Replace the hose and leave the flushing deal off. If the engine has overheated a little, it's good insurance to replace the thermostat. Do not get the Opti Spark wet replacing the thermostat. Take off a lower radiator hose and drain the anti-freeze into a container under the car. There is a petcock drain on the radiator, if you can get at that, drain the radiator that way. If not, take a lower hose off. You will have to remove the Mass Airflow with it's two bellows together. I just take off the air filter & all. Disconnect the MAF sensor and pull out the Opti-Spark vent hose from the Bellows. The thermostat housing is right there. Two bolts hold it on. Put a towel in front to catch any drainage to keep the Opti-Spark ignition dry.
Old Feb 15, 2009 | 10:51 PM
Ryan59's Avatar
Ryan59
I'm not sure where that flow control valve goes. I doubt the guy replaced the flow control with a flush deal?? Anything's possible. If you look around and find that black flow control, there should only be one.
Old Feb 16, 2009 | 12:47 AM
derekguzz's Avatar
derekguzz
ryan thanks alot. your help is what i have been looking for, along with everyone elses. I knew this thing wasnt stock on this car. its just stupid looking. thanks alot.
Old Feb 16, 2009 | 11:00 AM
  #33
Redeasysport
I told you in the beginning what it was I also gave you several ways to fix it. The flow valve is not totally necessary. That spot is a likely place to install a flush port to assist in flushing the motor. It makes it a lot easier than pulling the knock sensors to do it. You can get the flow valve (see previous links and observe the direction arrow) you can simply put a coupling, available everywhere, or you can put in a new flush port. The choice is yours. Good luck
Old Feb 16, 2009 | 11:25 AM
  #34
derekguzz's Avatar
derekguzz
would i benifit from having it?
Old Feb 16, 2009 | 11:41 AM
  #35
Redeasysport
The only benefit I see is if you spend a lot of time in higher RPM's such as a race car. All it does is restrict flow and possibly pressure to the Heater core not really an issue till the pump spins up.It does not turn it on or off like the earlier flow valves did,
"Coolant to the heater core comes from the water pump. The lower hose on the water pump is the heater core inlet, and should have a flow restrictor mounted in the hose. This is to prevent over-stressing the core at high engine rpms. The heater core outlet hose returns to the water pump at the upper hose connection, and also has a T-connector to the pressurized reservoir to bleed off any air."
http://www.impalassforum.com/vBullet...d.php?t=216026
Old Feb 16, 2009 | 12:16 PM
  #36
MikeC4's Avatar
MikeC4
Since there has been some confusion, and for reference, here is the location of the stock flow restrictor :
Old Feb 16, 2009 | 04:25 PM
  #37
derekguzz's Avatar
derekguzz
see a pic is what i needed for reff of where the stock one should be. 5 bucks says I have one there and some guy put the thing that broke in a line to help with the flushing. well this thread id helping with alot of confusion..
