Mystery?
Old Feb 17, 2009 | 10:34 AM
Patch's Avatar
Patch
Default Mystery?
I would appreciate any insight-When I initially turn the key(but do not yet power the starter)on my '85 L98, The fuel pump no longer comes on for a couple seconds as it should. This obviously leads to a loooooong crank to start(once on the engine runs normally to full RPM). Replacing the relay made no difference. I came to the point of installing a switch to directly power the fuel pump just at startup! Again, any help is appreciated.
Thanks-Tim.
Old Feb 17, 2009 | 10:43 AM
rick lambert's Avatar
rick lambert
Maybe you should check the fusible link. Also check the wires going into the back side of the fuel pump relay.
Old Feb 18, 2009 | 11:00 AM
Patch's Avatar
Patch
Default Mystery
Thanks for your response, Rick. The fusible link and wiring are good. Any other ideas?
Thanks, Tim.
Old Feb 18, 2009 | 03:23 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Put a test light on terminal "C" of relay and check to see if it lights up for 2 seconds, when ignition is turned to "run". If it doesn't, than the problem is between relay and ECM.
http://members.shaw.ca/agent86/Fuel%...20Delivery.pdf
Old Feb 18, 2009 | 03:33 PM
Patch's Avatar
Patch
Thanks for the info/advice!
Tim.
To Mystery?
