Tips on rear shock replacement needed!!!!!!!!!!
Old Jan 24, 2002 | 11:13 PM
24power's Avatar
24power
Default Tips on rear shock replacement needed!!!!!!!!!!
Got my Edelbrocks today..Gonna replace all four this weekend...Front ones look pretty straight forward but any tips on dismounting and remounting the front and rears will be greatly appreciated...trying to save as many knuckles as i can...........thanks!!!!!!.....Found a good price on the edelbrocks>>>>77.00 a piece for the rears and 119.00 a piece for the fronts. :cheers:
Old Jan 24, 2002 | 11:30 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: Tips on rear shock replacement needed!!!!!!!!!! (24power)
They are easy to replace. Get the car up on jack stands and take the wheels off for the easiest access. I use anti-sieze on the bolts/threads when installing the new ones. You will be much happier years down the road when you need to change them out again. I just changed the 10 yrs. old shocks on my van (this thing has been through 10 Minnesota winters mind you) and the nuts/bolts came right off. I'm glad I used anti-seize on them 10 yrs. ago. Good Luck.
Old Jan 24, 2002 | 11:57 PM
Rob 93ZR-1's Avatar
Rob 93ZR-1
From: Fear causes hesitaiton...and hesitation will cause your worst fears to come true. Houston TX
Cruise-In IV Veteran
Cruise-In VII Veteran
Default Re: Tips on rear shock replacement needed!!!!!!!!!! (Bob86ZZ4)
The rears are actually easier. Once the car is in the air and you are putting the new front shocks in, you may need to jack up under the hanging suspension to get the bottom bolts started. Should take you two hours or so.
Old Jan 25, 2002 | 12:12 AM
rocketfinger's Avatar
rocketfinger
Might have been the fronts, but I think I did the rears while the car was still wearing it's shoes, in a parking lot, no less. Too used to 4X4s, I guess. :rolleyes: I did take the wheels off for the other two and it was almost too easy. Wish I had thought of anti-seize, but my '94 only sees Minnesota summers. :D
Old Jan 25, 2002 | 07:51 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
On the rears the upper end of the shock is attached to a small plate. The plate is attached to the car with two bolts. Take them out, take the lower nut off and off the come. I reattached the top first and then used a jack to raise the suspension to realign the lower end. The whole thing went smooth except I had to use a hack saw to cut one of the front shocks off. If not for that I think I would have spent more time putting the car on stands than I did on the shocks. Have fun.
Old Jan 25, 2002 | 12:21 PM
MDC9966's Avatar
MDC9966
Default Re: Tips on rear shock replacement needed!!!!!!!!!! (joecaver)
On the rear, use a jack to take the pressure off the shock. It makes installation a breeze. The fronts were even easier.
To Tips on rear shock replacement needed!!!!!!!!!!
