Ignition switch
Old Feb 22, 2009 | 07:21 PM
electinspector's Avatar
electinspector
Default Ignition switch
I need help on this, I can't shut my car off. 86 Vette, when I turn the key to shut the car off,the motor is still running with key removed I has to pull ECM 3 amp fuses,then everything is off. Once I put in the fuses, the car start like normal,only problem is turning the car off. Do I has to replace the ignition switch or the key lock cyl ? Any help
Old Feb 22, 2009 | 08:30 PM
SunCr's Avatar
SunCr
There's nothing in the key lock - it moves a rod which moves the contacts in the ignition switch. Troubleshoot by dropping the column to access the switch. Operate it manually and see what happens and/or observe what happens while someone operates the key. More than likely, it needs a new ignition switch.
Old Feb 22, 2009 | 08:55 PM
l98tpi's Avatar
l98tpi
Max G’s
Old Feb 23, 2009 | 06:19 PM
electinspector
Thanks for information, I will check the switch..
Old Mar 9, 2009 | 11:17 PM
93VetteRev's Avatar
93VetteRev
1st Gear
I had an 84 that did this. Brought it home and couldn't turn it off. Turned out that i could turn off the car and pull out the key and the car was still running. The key was the headlight switch. for some reason, it kept the motor running. I never did figure out why, but thought it sounded like my experience.
To Ignition switch
