Hi Guys
I'm in the late stage of a cam replace. I was wondering if I should glue the tpi to the maniflod. I put permatex on the manifold to the heads, I just was wondering if it is needed on the TPI to the manifold.
I never used any sealers to attach the TPI to the intake or plenum.
What gaskets are you using? Mine were stock/fel pro design that crush seal into place on install.Some other aftermarket brands,say,Mr gasket,thats flat on both sides,may benefit from some sealer,if the metal areas for gaskets,are way off specs.
