CCM/BCM question>
With the install of the 91 dash I need to get the mileage and everything set-up correctly
http://www.thirdgen.org/newdesign/tech/promintro/shtml
AND
http://www.eecis.udel.edu/~davis/z28/ecm_swap_730
Hope this points you in the right direction.
I've never run across a CCM hack. Thought it was a 'dealer only' mod, since it contains the odo and pass-key readings.
Try the TC board - there are some dealer techs who post there.
