compression?
Old Feb 26, 2009 | 03:12 AM
kaislick's Avatar
kaislick
Default compression?
I'm building a '95 LT-1, it's now a 383 stroker and I'm going the supercharger puts out about 8 lbs of boost. What is the max compression I can run on this motor? Does anyone know the ratio of cc's removed from the combustion chamber = what compression reduction? Any help appreciated, I've spent my time on a NA C6 the past year and now its time to beef up the C4!
Old Feb 26, 2009 | 10:33 AM
mn_vette's Avatar
mn_vette
Are you only going to be running 8psi on the 383ci? If you lower the CR you can run much more boost and have more HP overall. If you are planning on sticking to 8psi then 10:1 would be ok. For more than that I would go around 9:1.
What kind of pistons/crank and heads do you have? Chances are its going to be either new pistons or new heads if you want to lower the CR.
Old Feb 27, 2009 | 04:48 AM
Snakecharmer383's Avatar
Snakecharmer383
For a short time I ran 6-8 boost with 10.7 cr then I melted the head between 3-5 cylinders.
Old Mar 8, 2009 | 07:28 AM
"swamp rat"'s Avatar
"swamp rat"
Too much cr, you don't want to go over 9:1 9:5 Max!!! There are some out there running 9:1 with 12lbs. of boost !! Makin 650 RWHP! with a 350ci !!! I'M building a new engine a 355 ci with 9:1 cr I run nitrous & that works the same as a blower! you can get more out of It without a melt down!!!!
Old Mar 8, 2009 | 04:54 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Decided to keep my compression @ 9:1 in case I want to pump my S-trim up to a T-trim.
Old Mar 8, 2009 | 11:13 PM
AKS Racing's Avatar
AKS Racing
As I have said many times in prior posts, on a SC'ed street driven application, you want to keep the compression around 9.5:1+ SCR (even 10:1 is OK) or you wind up with a fairly "lazy" combo below 3000RPM. And we must all remember that for street cars (that are driven many miles in stop in go traffic) 3000RPM and below is where these cars will spend 95% of their life.
Now if it was for a weekend warrior, then I am in full support of lowering the compression further and raising the boost considerably.
Bottom line: 8 psi should be fine with 9.5:1+ SCR with a decent tune.
Aaron
Old Mar 9, 2009 | 07:49 AM
larry00's Avatar
larry00
I can testify that my 383 w/9.8.1 CR and 8 lb.s blew both head gaskets at 6800 rpms on the dyno.
I decreased RPM's to 6200 and now I'm either going to put supercharger back on or replace JE dished blower pistons and put in a milder cam.
It ran great at 6200 but I sold the Procharger [ a mistake ]
I figure a couple of grand to reconfigure the engine without the blower.
So I guess I'm looking again for a blower and will stay with 6200 or lower !
Anybody got a P 1SC laying around they want to get rid of ?
Got Cash ! LOL
Old Mar 9, 2009 | 06:32 PM
"swamp rat"
Got Cash ! LOL
Get in line larry!!!
Old Mar 9, 2009 | 09:40 PM
larry00's Avatar
larry00
E Bay kit $ 4995 guess I will buy new ! D upgrade another $ 400.00
I can deal with that too .
going right now to check out the D upgrade at Procharger.
Old Mar 9, 2009 | 11:16 PM
AKS Racing's Avatar
AKS Racing
Got Cash ! LOL
Why were you spinning the 383 to 6800? Hellacious cam, huge heads? Was power still increasing significantly above 6200?
I do not believe that the 9.8:1 SCR was the cause of the blown head gaskets at 6800RPM at 8 psi. 8 psi is 8 psi whether at 6200 or 6800 (or 4800). IMHO, there must have been other contributing factors to the failed head gasket.
I still firmly stand behind the 9.5 - 10.0 SCR recomendations for lower boost settings, provided the tune is up to par.
Aaron
BTW, skip the P1SC and go for the engine oil cooled D1
To compression?
