Radiator leak
Old Feb 26, 2009 | 07:30 AM
joe3906's Avatar
joe3906
Default Radiator leak
Sprung a leak in my 96 LT4, can a leak be repaired without replacing the radiator. And, if the radiator is replaced, should I keep the OEM one? In the past you could have a radiator boiled out and repaired, are those services still available?
Old Feb 26, 2009 | 07:45 AM
runner140*'s Avatar
runner140*
Take it to a radiator shop and they will pressure test it to find out the location of the leak and if it can be welded (patched). Over 50% can be repaired without a radiator replacement.
Old Feb 26, 2009 | 08:36 AM
joe3906's Avatar
joe3906
Thanks, that's what I'll do. The mechanic is going to install a new one, and I will take the OEM radiator and have it repaired. I guess I'm old fashioned, I like to keep the stock parts on this car. Again, thanks for your suggestion, it is a good one.
To Radiator leak
