Front end Wedge Brackets
Old Feb 26, 2009 | 11:47 AM
rte203's Avatar
rte203
Default Front end Wedge Brackets
I have an 85' c4, Do I have to change the Brackets from steel to aluminum when lowering the front end or can the steel ones be used?
Old Feb 26, 2009 | 12:48 PM
Epimax's Avatar
Epimax
Yes, you do need to change them out..
The upgraded brackets are needed because they've got to be trimmed to match the shorter wedge height. I suppose the steel brackets could be used, but you'd have to cut/weld them somehow. The upgraded brackets are aluminum, and can be easily trimmed!
Old Feb 26, 2009 | 01:20 PM
rte203's Avatar
rte203
I was afraid of that . thanks for the Info
Old Feb 26, 2009 | 03:21 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I cut and welded the originals. Not a big deal if you have access to a mig.
To Front end Wedge Brackets
