Trick battery tender install?
Old Feb 27, 2009 | 07:23 AM
steve mulherin's Avatar
steve mulherin
Default Trick battery tender install?
Has anyone come up with a battery tender install that you can plug in without lifting the hood?
Old Feb 27, 2009 | 08:37 AM
Dudeurgettnavette's Avatar
Dudeurgettnavette
you could make an access door in wheel well
Old Feb 27, 2009 | 08:58 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I've often thought about this but I have never found a mountable female receptacle that is small enough to be discreet. If you could find a small receptacle and then get a male plug-in to go with it you could mount it flush with the outside of the wheelwell. Maybe Radio Shack???
Old Feb 27, 2009 | 09:42 AM
UNCLEBILL's Avatar
UNCLEBILL
On my 1990 Vert; I installed a s/steel grid under the nose to stop stuff getting inbetween the rads. This allowed me to drill a hole in it and put a grommet in it. I then ran wiring from the battery thru the hole with the plugin thru the grid. I have my Battery Tender(acually the AutoMeter one) mounted on my garage wall with a extension to plug into the one under the nose. To keep the plugin under the nose from dangling; I used one of those small plastic wire clip holders connected to the s/steel grid and just hooks onto it. I did make a cap to plug into the plugin on the car. It makes for a easy plug in when I pull into the garage after a cruise.
Old Feb 27, 2009 | 09:58 AM
STL94LT1's Avatar
STL94LT1
On my C5 I hard wired a Battery Tender Plus' cord to my battery. Then used their optional extended cord to route the plug coming out where the Driver's side hood and fender meet. I just pull in the garage, plug it in and I'm done. I'm sure the same routing can be done on the C4, no holes need to be cut, and you can route it on either side of the car depending on where the charger is mounted in your garage.
Old Feb 27, 2009 | 11:34 AM
NEVRL8T's Avatar
NEVRL8T
Mine plugs into the cigarette lighter.
Old Feb 27, 2009 | 01:38 PM
flhtc01's Avatar
flhtc01
I just bought a battery tender and installed the "pig tail" to the battery using GM Post Adapters from NAPA. Th adapters are brass and cost about $5. They replace the stock battery cable bolts. I then ran the other end of the "pig tail" down and out of one of the gills on my '89. Pull in the garage, grab the plug out from the gill and plug it into the tender. Couldn't be easier.
Old Feb 27, 2009 | 03:07 PM
TA's Avatar
TA
I believe Mr. Mojo ran his wire out through the gill panel. You can pull the wire out and plug it in and when you're done you tuck it back in the through the gill panel.
To Trick battery tender install?
