electronic spark control help
Old Feb 27, 2009 | 05:06 PM
hill's Avatar
hill
Default electronic spark control help
My 90 vette is giving me an electronic spark control code. Is the electronic spark control in the ECM if not were is it. If so do i have to replace the ECM to fix it
Old Feb 28, 2009 | 04:31 PM
hill's Avatar
hill
Anybody
Old Mar 1, 2009 | 11:50 AM
woody1243's Avatar
woody1243
The ESC module on my 84 is on passenger side next to blower. It is a flat pack with 4 wires going to it. It could also be knock sensor located down by starter.
Good luck.
Woody
Old Mar 1, 2009 | 03:03 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Details? What code is it setting? The ESC module is an independent piece of hardware, and does not require replacement of the ECM in almost any code issue.
Old Mar 1, 2009 | 03:49 PM
hill's Avatar
hill
I will have to look at the code again but i think it was 43.
Old Mar 1, 2009 | 06:04 PM
hill's Avatar
hill
yea it is code 43 were is it located at? I have Mitchel on demand on my pc and the Chilton book and nether show it
Old Mar 3, 2009 | 10:51 PM
hill's Avatar
hill
Anybody
Old Mar 4, 2009 | 05:48 AM
woody1243's Avatar
woody1243
Did you read my response days ago?
Woody
Old Mar 4, 2009 | 09:30 AM
hill's Avatar
hill
Woody
Yes i did mine is not there. Your 84 has a different wiring set up than mine thank tho
Old Mar 5, 2009 | 08:47 AM
woody1243's Avatar
woody1243
Well I tried. You need someone with a FSM for your year to help. Good luck.
Woody
Old Mar 5, 2009 | 08:39 PM
69427's Avatar
69427
I don't remember which year it was, but the later L98 ECM incorporated the ESC electronics into the internal Memcal unit. If you don't have the external module, I would assume yours has the internal board.
Old Mar 5, 2009 | 10:33 PM
hill's Avatar
hill
So i will have to replace the ECM. I seem to only come on when its real cold out side. It just started coming on with the cold weather now that it in the 60s low 70s it has not come on. When it was cold out it would come on an off every few mins
Old Mar 6, 2009 | 10:19 AM
69427's Avatar
69427
As I mentioned earlier, not necessarily. The memcal unit just plugs into the ECM board. If there is an actual issue with the ESC electronics (very rare due to the robustness of the hybrid circuit technology), you can just replace the plug in memcal, not the entire ECM.
There are a couple issues to debug first. The knock sensor connection is somewhat fragile. Check to make sure that the connector pin is making a good mechanical and electrical connection to the sensor. I suppose there is also the slight possibility that there is a marginal solder connection in the ESC circuit, or in an ECM connection that the ESC signals travel through. Replacing everything gets expensive. If you have the time and ability, it might pay to try to narrow down the problem area.
Old Mar 6, 2009 | 06:07 PM
hill's Avatar
hill
I have the time do to layoff and i have the ability and tools so i will check it out Thanks
Old Jun 6, 2009 | 11:30 AM
raptor61's Avatar
raptor61
6th Gear
Default having same problem, did you solve yours??
Have the same issue with my 90
Was wondering if you had any luck with solving your issue?
Old Jun 7, 2009 | 04:59 AM
rodj's Avatar
rodj
Same code 43? knock sensor .
As noted by 69427 above;
code indicates a problem in the circuit; the ECM is not getting correct signal from sensor.
Could be faulty sensor or just bad connection on wiring back to ECM.
Need to check wiring is OK with DVM first before replacing parts.
Old Jun 8, 2009 | 11:21 AM
raptor61's Avatar
raptor61
6th Gear
Have done all the tests listed in the service manual diagnostic flow chart and it says to replace the memcal. Can't find the memcal for sale anywhere.
Any other ideas or suggestions?
thanks
Old Jun 20, 2009 | 03:34 AM
rodj's Avatar
rodj
Have done all the tests listed in the service manual diagnostic flow chart and it says to replace the memcal. Can't find the memcal for sale anywhere.Any other ideas or suggestions?
thanks
Get someone like PCMforless to burn you a new memcal with the '90 Corvette code on it.
http://www.pcmforless.com/
Old Aug 4, 2009 | 09:42 PM
raptor61's Avatar
raptor61
6th Gear
thanks for the info!!
To electronic spark control help
