Problem at restart.
Old Mar 1, 2009 | 06:49 AM
RED UFO's Avatar
RED UFO
Default Problem at restart.
I have a 91 vert with 150K. When the engine is at normal operating temp and I shut it off for a few minutes, then when I restart it the idle fluctuates between 900 and 1100 rpm or it will start and stall unless I keep the rpms up for 10 to 15 seconds. Once I keep it reved up the idle will smooth out.
Does anyone have any idea what my problem is?
Old Mar 1, 2009 | 08:09 AM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
do an ohm check on each injector. When those multecs get hot they have a tendency to fail. If they are the original, they should check out at 14-16 ohms. if any are below 12 you have to replace the set. do this check cold then hot and post the results
Old Mar 1, 2009 | 08:20 AM
RED UFO's Avatar
RED UFO
I have pink top injectors.
They were there when I bought the car at the end of 2007.
Old Mar 1, 2009 | 08:31 AM
FICINJECTORS
Supporting Vendor
those really don't have problems. start looking at the sensors, Iac etc. make sure its going into closed loop. check fuel pressure at the rail and make sure you are not loosing rail pressure. but, with the erratic idle i would lean towards a sensor. do you have any codes?
Old Mar 1, 2009 | 10:08 AM
RED UFO's Avatar
RED UFO
I have no check engine light so I have not looked for codes.
The only code I have is in the climate control due to a freon leak (9).
Old Mar 1, 2009 | 11:38 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Sounds like a leaky FPR to me.
Old Mar 1, 2009 | 12:02 PM
MikeC4's Avatar
MikeC4
...I would first check your fuel pressure, especially when it is erratic. I would then look at the IAC. Sounds like you may have a "lazy" IAC.
Old Mar 1, 2009 | 12:12 PM
RED UFO's Avatar
RED UFO
I have a FSM but will you please define IAC?
Old Mar 1, 2009 | 12:14 PM
RED UFO's Avatar
RED UFO
I will follow up on all these suggestions. I would like to remind everyone that it starts cold just fine.
Old Mar 2, 2009 | 12:34 AM
Redeasysport
Typical of a bad FPR after it sits long enough for the fuel to evaporate. Pull the vacuum hose off the intake to it and smell it if it smells like gas it is toast.
IAC is Idle Air Control valve near the bottom of the TB. You can get a can of TB cleaner and shoot it into the hole in between the blades. That is where the air goes into the IAC passage. I do mine ocassionally and spray till it stalls the car at idle to fill the passage and let it sit for a few min. If you ever looked in one of these intakes you would be shocked at the "cokeing" that occurs from shutting the engine off and back flow from the pistons into the intake. That is why the back of the TB blades are black. It gets into the IAC passages too.
Old Mar 2, 2009 | 01:12 AM
RED UFO's Avatar
RED UFO
I will check this tomorrow. What is a normal fuel pressure at idle?
Old Mar 2, 2009 | 11:24 AM
Redeasysport
~40psi. The key test here is what happens when the engine shuts off if the FP drops quickly either FPR is bad or stuck injector usually especially when there is a hard start when warm condition. Be careful pulling the vacuum line after the rail is charged as it may shoot fuel out.
Old Mar 2, 2009 | 06:29 PM
RED UFO's Avatar
RED UFO
I will pick up a gauge.
To Problem at restart.
