Lo AC head pressure > 189
Hi AC head pressure > 225
Originally Posted by theadmiral94
Hman1987,
Your understanding of how your fans work sounds like it has been confused by all the differences between the C4 years.
As mentioned above by a few:
1. the 1996 LT1 has two fans.
2. BOTH fans should run together (i.e. at the same time).
3. With AC OFF, BOTH fans should run at 'slow' speed when the digitial coolant gauge hits or exceeds 228 F.
4. With AC OFF, both fans should run at 'high' speed when the digital coolant guage hits or exceeds 236 F.
5. With AC ON, both fans should run at 'slow' speed almost immediately.
6. With AC ON, if EITHER the digital coolant gauge reads above 236 F -OR- the AC pressure exceeds a pre-set pressure (typically hit during hot weather), both fans should run at 'high' speed.
If only one fan is running at any time, either one of the 3 relays has gone bad (on the driver side of the radiator cover) -or- the non-running fan motor has gone bad -or- there is a wiring problem.
The suck part of all this, as I see it, is that one beneficial feature of the LT-1 is the reverse-cooling, that puts cooler coolant to the heads first, enabling operation at lower cc temps and slightly higher comp ratio. Yet, at the same time, factory set the cooing fans to not kick in until the coolant was much hotter than a standard passenger vehicle stat temp of 195. Kind of defeats the purpose and offsets the benefit of the reverse-cooling, to set the thing up run hotter. Running hotter like that makes more knock, causing timing retard and power loss, and loss of abiity to take full advantage of LT1's capabilities.
Reason: because I can
If I keep at highway speeds, there's no issue, but sitting at a standstill the temp creeps up in to the 230 range eventually. Then if one gets on the highway it cools down after about 5 miles of driving. I'm not complaining, just observing. Although it's a redundant statement I'll say it anyhow: these cars weren't designed to sit still !!
Seems your car is operating exactly as designed then.
If your sitting still at a traffic light, there is no airflow moving across the radiator.
Airflow moving across the radiator is what dissipates the heat. Once the temp. reaches the pre-programmed level, your fans kick on and the temp
will begin to drop until the temp. reaches another pre-programmed level and they will shut off. This cycle will continue as long as you sit there.
Even though some people think those programmed on/off fan settings are too hot, that is the way they were designed.
If that is too hot for you, you will need to make modifications to your cooling system design. It can and has been done.
