Dangerous Suspension Problem
Old Mar 2, 2009 | 03:03 AM
techvette's Avatar
techvette
Default Dangerous Suspension Problem
I just picked up a 96 LT4 with 60K on the clock yesterday from a dealer in another state and drove it back.
My issue is that when you take any but the gentlest left-hand corner / curve the back end swings out all of a sudden. The car doesn't break traction, but just bumps the back end out. The first time it did this I almost put it into the expressway barrier.
Another car I had exhibited similar symptoms once and it was a suspension bushing stepping over where it was supposed to shoulder up.
I don't know much about the design of these cars yet, as I JUST bought one. Can you guys please help me diagnose this problem?
Problem 2: The brakes seem to work fine, but when you turn a corner / sharp curve / park the driver side rear brake makes a horrible metal on metal shrieking noise. I immediately think brakes, but they don't grind when stopping and seem to work fine. Thoughts?
Old Mar 2, 2009 | 06:11 AM
86PACER's Avatar
86PACER
I take it you did not even test drive the car before buying it.
Get under the car and check. There is nothing mysterious about the suspension on these.
How to raise:
Click HERE
Old Mar 2, 2009 | 06:57 AM
RichS's Avatar
RichS
Check the wheel bearings. They may be bad.
Old Mar 2, 2009 | 09:37 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
after that the bushings, toe link & u-joints.
Old Mar 2, 2009 | 10:04 AM
jhammons01's Avatar
jhammons01
^^like those two said, you have a floppy wheel in the back. Many things could work together to cause what you are experiencing.
Old Mar 2, 2009 | 10:10 AM
neat's Avatar
neat
I had a wheel bearing failure that was letting the rotor touch the caliper bracket when I turned corners. That sounds like what you are describing.
It's easy to check, just jack up the car and wiggle the wheel.
Old Mar 2, 2009 | 11:11 AM
techvette's Avatar
techvette
Anyone have a diagram of the rear suspension assembly? And can anyone recommend a good parts source?
Old Mar 2, 2009 | 11:20 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Drawings galore in the FSM, if search is working look for "blackharleyman" he posted lots of pictures of his suspension. There are also lots of other posts here with rear suspension pictures.
For parts depends on what you need. Wheel bearings - Corvette recycling has a great deal for NOS rears.
I bought my master bushing set directly from energy suspensions if I recall correctly.
I bought the sway bar and end link bushing set from Summit Racing. moog outer toe ends from RockAuto.
And from your description you have something broke or disconnected back there.
Mine was "sloppy" until I replaces all the bushings and hubs. Now it feels much tighter.
My passenger rear hub had a little play and when I took it off it fell apart in my hands!
Old Mar 2, 2009 | 11:37 AM
techvette's Avatar
techvette
Is there a downloadable FSM available?
Old Mar 2, 2009 | 12:00 PM
Iroc57's Avatar
Iroc57
I think that the GM lawyers keep this sort of thing on a pretty tight leash. You can usually find one on fleabay for around $100 or if you get lucky in the FS section here. Post a WTB thread and someone may have one for you.
Old Mar 2, 2009 | 02:12 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
This is something I'd pay for but not so suer if I'd share it.
The FSM is my best friend.
me too
Old Mar 2, 2009 | 02:50 PM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
Mine did the exact same thing when a rear wheel bearing went out.
Old Mar 2, 2009 | 04:22 PM
jhammons01's Avatar
jhammons01
Yeah, His name is Agent86. Look him up...befriend him....send him a 6-pack
Old Mar 2, 2009 | 04:34 PM
86PACER's Avatar
86PACER
His is for the '86, OP needs '96.
Old Mar 2, 2009 | 04:43 PM
jhammons01's Avatar
jhammons01
I'm not so sure, Agent86 has always sent me info for an '84.......
Old Mar 3, 2009 | 09:04 AM
techvette's Avatar
techvette
Well it turns out the issue was more dangerous than I thought. It was the front wheel bearing (also causing the metallic grinding noise by grinding the rotor on the mounting bracket). It had SICK amounts of play in it. I took it to a Vette shop and the owner said it's the worst he's ever seen! I mean this thing was literally ready to fall off!
The part looks pretty new, but it was some cheap Chinese replacement part...It had no lubrication in it and over the course of my 1200 mile drive back to Texas it had eaten itself alive. It got so hot that parts of it had actually oxidized.
So I'm having it fixed (with an AC Delco part) and picking it up later today. Hopefully I can just drive it and enjoy it for awhile now...
Dang those wheel bearing are expensive!!!
Old Mar 3, 2009 | 12:52 PM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Replaced both of my fronts with the suspension rebuild, $200 each for timken at autozone.
To Dangerous Suspension Problem
Old Mar 3, 2009 | 01:07 PM
techvette's Avatar
techvette
That's actually pretty cheap. I know there's a bit of a price markup on parts from a shop, but an AC Delco one is running me around $500 from the shop, maybe a little less. The quote was $589 installed.
Old Mar 3, 2009 | 01:26 PM
LannyL81's Avatar
LannyL81
Yeah....a large mark-up. $200 from Corvette Recycler here on the Forum..for GM parts.
Very easy to install.
Plan on doing the other one soon.
Old Mar 3, 2009 | 02:10 PM
NEVRL8T's Avatar
NEVRL8T
There is the problem! Lots of warnings have been posted about that.
Especially when you have the work done by a shop.
