1986 Corvette Auto Shifting Problem Please Help
Old Mar 2, 2009 | 01:14 PM
Dash8264's Avatar
Dash8264
4th Gear
Default 1986 Corvette Auto Shifting Problem Please Help
Hi there well Im New to the whole Corvette Seen. Just picked up My first corvette last night. Its a a 1986 C4 Automatic and Im having some problems with the Trani. It shifts from 1st to 2nd perfect but after theat It revs And Goes into 3rd at a high rpm but wont go into 4th or overdrive just stays in third. Im not sure what it could be. If you can Give me an Easy Explination That would be great. Thanks guys
"Drink And Get
Old Mar 2, 2009 | 01:23 PM
Iroc57's Avatar
Iroc57
"Drink And Get
At what MPH does it shift from 1-2?
Old Mar 2, 2009 | 01:25 PM
Dash8264's Avatar
Dash8264
4th Gear
it shift normal from first to second around 2500 rpm
Old Mar 2, 2009 | 01:30 PM
Pete K's Avatar
Pete K
"Drink And Get
You trans has a hurt 3-4 clutch pack, and possibly (although doubtful), and servo/band issue.
A rebuild is required. That is as simple as I know how to say it.
To anticipate the next questions:
1) Changing the fluid and filter will not help.
2) No. A repair is not feasible, as it is internal, and almost full disassembly is required to reach the problem.
3) Yes, you must change the torque converter, as it is worn, and debris from the failure is trapped inside.
4) Depending on where you are in the US, $1000-$2500 is what it normally runs.
Old Mar 2, 2009 | 01:40 PM
Iroc57's Avatar
Iroc57
Pete is the resident trans expert so his advice is as sound as you will find. The fact that you are shifting 1-2 normal rules out a simple adjustment.
He has answered these questions may times as you can tell.
Good Luck
Old Mar 2, 2009 | 01:52 PM
Pete K's Avatar
Pete K
Good Luck
I have delivered the bad news many times.
Sometimes, like ripping off a band aid, it is easier in the long run to just blurt it out.
Old Mar 2, 2009 | 02:13 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
I was going to type that it was the clutch pack but you beat me to it. I havent seen your post in awhile?
To 1986 Corvette Auto Shifting Problem Please Help
