Hey Guys,
I have a Canton Road Race pan that was originally used in a 96 Camaro. I want to use it with a motor I'm building for my 85 Vette. Is this pan going to fit ok, or am I going to have some kind of clearance problem?
I have a 7 quart Moroso pan on my 84 with dual kickouts. I have no problems with clearance. I have long tube headers and am using a small starter. The c4's have no crossmember underneath the pan so it shouldn't be a problem. Hoses may need to be rerouted. I am also using a remote oil filter so I can use a extrra capacity oil filter that would otherwise interfere with the pan kickout. If ou're running the stock filter, it shouldn't be a problem.
