Do you have to remove the gear and bearing above the camshaft to get rid of the mechnical side of the pump. Then you freeze plug the timing cover right?
Do I have to freeze plug where the bearing was on the engine side? Or is it ok to let the oild flow thru it?
Yes you should remove the WP drive gear assy. Then you need to put a plug in the timing cover.
It's fine to leave the hole left by the WP drive assy in the block alone.
So I take the reluctor ring off and just tune out the cps code right? Nothing goes in place of the ring???
Yes. The only thing different is you will need use the Harmonic Balancer hub off a 92-95, or if you buy an aftermarket balancer buy one for a 92-95 (it is longer).
Will
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
You should never let gears run or freewheel without some load on the
teeth. You would just be asking for trouble later. At a minimum,you should at least press the gear off the shaft and let the shaft still be used with the seal in the cover if you don't want to plug the cover hole. This would allow you to go back to the mechanical pump later if you should decide to.
The aftermarket dampers like the ATI super damper for the 94-96 cars I use comes with about an .080" spacer ring that makes up for the crank sensor ring if needed.
Rick
You can leave it, but you'll end up with a nice oil leak since the shaft will be unsupported. Remove the screws that secure it and drive it out from behind. You can leave the hole open, no need to plug it.
Add a freeze plug to the timing cover. As long as the plug is somewhat snug, use The Right Stuff or epoxy (ie JB Weld) to hold it in place
Alright I had a bastard of timing getting a freeze plug to fit. I ended up putting a 1 1/8 freeze plubg in there but its loose. Im not comfortable with that process so IM going to go to the machine shop and get them to do something perminate.
Ill remove the gear when I get home and Ill next day a harmonic balancer in.
Pulling the sprocket on the crank, what did you guys use?
Im looking on summit I dont know what balancer to get. None of them say a difference between the 1996 1995. Can some get me a part number that would be great. I see that 1996 run a 3.417 and the 1995 is 3.516.
Im thinking that its the ATI 917274 from summit. And like rick says it comes with a spacer so I guess thats it.
They also make one in summit but do you think this is a good replacement. http://www.jegs.com/i/JEGS/555/51607/10002/-1
Im not too concerned with top brand products, Im planning on a 383 forged build that will get all the good stuff. This stock short block 350 Im running now will probly blow up.
Also I can leave the sensor (CPS) in place to plug the hole right? Or should I freeze plug that too?
I used the ATI 917269 on Nolands 96. Incidently I had to REMOVE the spacer for it to line up correctly with the accy drive. I also was using the Cloyes double roller timing set.
The balancer can always be transfered to your new 383 when ever you do that swap. IMO it's one less high dollar part to buy later.
You can just leave the sensor in place on the timing cover or plug it -whatever you want to do. I left the sensor in the cover on Nolands engine and hasn't leaked a drop so far.
One last thing. The waterpump drive shaft hole in the timing cover. A Volvo B21 valve adjustment shim presses in there perfectly and then just seal it up with some epoxy.
Will
Will
I'm actually thinking of putting a mechanical back on.
The old engine was generally in the 220s. For the new engine I'm switching back to the mechanical pump. With an extra 100+hp the electric won't keep up IMO.
I'm using the 917275 balancer (pics are in my 383 thread). It's slightly underdriven (5% on the LT4, 10% on the LT1) but will work fine.
Regarding the CPS...Same answer as before...leave it. It doesn't intrude into the cover. You'll see that once you get your cover back and test fit the sensor.
So all you need is that balancer and it ready to go right? Or do I need to change the hub?
I have mine at the shop its ready to pick up. They didn't weld it cause they were afraid of warping with using heat. Ill see what they did tomorrow.
Did you get it back yet? I brought mine to an exhaust shop and they said they could not weld a 50 cent piece to aluminum. I got some aluminum stock that I am going to try and cut to the same shape then bring it to a full weld shop. I found a bunch in the phone book.
How did they do yours?
I took mine to the performance shop has them press in a freeze plug and then epoxy around it. Cost me $30.00
I used a feeze plug and JB weld. I paid alot of attention to getting the area cleaned and prepped first. I used some 150grit to rough up the surface on the edge of the freeze plug and the inside edge of the timing cover to give the epoxy a rough surfce to adhere to. No problems so far.
