Auto door locks don't work
PKE = Passive Keyless Entry
So, the doors are not supposed to lock by pushing the remote button.
What you hear when you hold the button down, is the locks cycling. This is how you turn the PKE system on or off.
If the system is on, the doors should lock as you walk away from the car. And then unlock as you walk back up to the car. No button pushing required.
If the system is off, then nothing is supposed to happen and you lock or unlock your doors manually or with the switch on the door.
The alarm will still be armed when you lock the doors.
You probably need to read up some on the PKE system.
Everything is explained pretty good in the owners manual, but I am guessing you don't have one of those yet?
You can find one in pdf format here:
http://corvette-world.com/free-corve...nual-t-21.html
I am at work right now, and can't spend a lot of time searching so maybe someone else will chime in with more details.
In the meantime, just do some searching on the PKE system. Should be lots of stuff out there.
I say this with the assumption that you have the factory PKE/alarm system.
