Brace for the AC compressor?
Old Mar 7, 2009 | 04:59 PM
Ripps's Avatar
Ripps
Default Brace for the AC compressor?
I have a brace off an '89 L98 and not sure where or how to mount it.
I have two shorter braces, one connected to the A.I.R. pump and the other to the altenator. But I also have another longer brace that I think probably supports the AC compressor. (see image)
http://i432.photobucket.com/albums/qq42/Ripps/brace.jpg
If you could identify where each end connects and possibly provide a picture it would be most helpful.
Thanks!
Old Mar 7, 2009 | 06:35 PM
Calderone's Avatar
Calderone
i thought i could help but ive never seen a brace that long !!!
Old Mar 7, 2009 | 06:40 PM
rodj's Avatar
rodj
Goes from exh manifold stud above # 4 spark plug to
top rear compressor mounting bolt (outside )
Should also have 4" long brace with bend in it
Goes from stud on fuel block of plate to A/c bracket behind idler pulley.
Recall there is a 3rd brace , lower front A/c mounting bolt (inside )to waterpump stud
Old Mar 7, 2009 | 06:43 PM
Calderone's Avatar
Calderone
Originally Posted by rodj
Goes back to the exh manifold stud above # 4 spark plug
is that a L98 Brace ?
i dont have that
Old Mar 7, 2009 | 06:59 PM
rodj's Avatar
rodj
i dont have that
Sammy ,
'87 has different compressor (Harrison ) on different bracket. Mounts closer to engine so additional braces not needed.
Note in pic the compressor is outboard of head on later models
Old Mar 7, 2009 | 07:01 PM
Calderone's Avatar
Calderone
Sammy ,
thanks for the clarification...i was starting to thing i had a missing brace hehehee
Old Mar 8, 2009 | 11:58 AM
tachout's Avatar
tachout
If you look in this picture:
You can see it going from the back of the compressor, to Exhaust manifold stud as listed. Mine is laying on the bench right now as my engine bay is dissassmebled, but that is where it is.
Old Mar 8, 2009 | 12:13 PM
Ripps's Avatar
Ripps
Default Thanks!!
Yes, I thought it would be something like the brace you show on top but wasn't sure exactly how it went on.
Thanks!!
Old Mar 8, 2009 | 12:31 PM
jeffp1167's Avatar
jeffp1167
Sammy ,
Hell with the braces, I wanna know more about that filter mounted on this plenum LOL
Old Mar 8, 2009 | 05:28 PM
rodj's Avatar
rodj
So do I ,
this is a engine I bought interstate and haven't picked up yet ;the pics show some weirdstuff.
Mind you ,the greenie owner pulled a 40K engine out of a '89 to put in a diesel .
Is going to take it to the USA for some enviromental challange
To Brace for the AC compressor?
