Fuel pump wiring route?
Old Mar 8, 2009 | 03:22 PM
pivotpro's Avatar
pivotpro
Default Fuel pump wiring route?
I just removed and marked all wiring harness connections. The interior of my car is completely stripped except a bucket to sit on. I cant get the car started now. There is no pressure in the rails, and I am sure that somehow the fuel pump is disconnected or something I disconnected is a safety feature that is disabling the fuel pump.
Please give me all ideas, as I would like to pull the car into the garage (steep driveway, otherwise I would just roll it in).
I have reconnected and grounded all fittings on the harness to the rear part of the car. I did find a horribly deteriorated pair of fittings that power the tail lights at the rear passenger side of the car. I have several pins corroded right off,, and some wires have pulled loose. Could this be where the fuel pump is routed through?
BG
Old Mar 8, 2009 | 05:20 PM
rodj's Avatar
rodj
Are there wires still connected at the fuel pump?
Old Mar 8, 2009 | 05:55 PM
pivotpro's Avatar
pivotpro
Never even went near the fuel pump. I can check it out in the a.m. though.
To Fuel pump wiring route?
