high idle
Old Mar 8, 2009 | 06:55 PM
Green93Hornet's Avatar
Green93Hornet
Default high idle
1993 LT-1 idles at 1100 rpm when hot or cold from start up. Could it be a vacuum hose?
Old Mar 8, 2009 | 08:02 PM
Corvette86's Avatar
Corvette86
St. Jude Donor '06
Verify your car is going into closed-loop when warmed-up. Use a OBD1 scan tool for this. Let us know what you find.
Frank
Old Mar 9, 2009 | 10:21 AM
Green93Hornet
Thanks but you are talking over my head. I don't have a scan tool, nor do I know how to use one. Guess I'll have to bring it for service.
Old Mar 17, 2009 | 12:49 PM
Corvette505's Avatar
Corvette505
Seems like if i set my timing around 6/8 BTDC than it will accelerate no problem, but the idle after warming up is a bit up and down. Now if i turn the distributor clockwise it lowers my timing, get a nice idle, but when i "punch" the gas i get a little hesitation, which just drives me nuts. Any suggestions????
Old Mar 18, 2009 | 06:15 AM
5abivt's Avatar
5abivt
Im confused. is the above post a reply to the original post or a question in someone elses post ?
Old Mar 19, 2009 | 01:03 AM
Corvette505
well, it's another idle problem......
Old Mar 19, 2009 | 03:52 AM
FOXX's Avatar
FOXX
Don't feel bad. If it's anything like my thread it won't even get any lookers. Oh well, I'll just try the OBD1 thing.
Old Mar 19, 2009 | 03:53 AM
FOXX's Avatar
FOXX
Frank
What does it mean if it doesn't go into closed loop?
Old Mar 19, 2009 | 04:31 PM
383vett's Avatar
383vett
Maybe your throttle blades have for some reason opened up too much. Maybe lower the throttle blade opening adjustment 1/2 to 3/4 or a turn to see it this helps.
To high idle
