Help: Engine Sensor behind the starter.
Old Mar 12, 2009 | 08:05 PM
fbelz's Avatar
fbelz
Default Help: Engine Sensor behind the starter.
1985 Corvette. There is a sensor located in the block on the sloped surface behind the starter. It has a single wire going into it. On my car it is broken and the wire is hanging loose.
Anyone been into this thing?
Fred
Old Mar 12, 2009 | 08:13 PM
captmike13's Avatar
captmike13
Cruise-In IX Veteran
From what I can gather from the FSM it is the fan override switch.
I'm sure someone else will chime in and correct me if I'm wrong.
Hope this helps.
Mike
Old Mar 12, 2009 | 08:22 PM
rodj's Avatar
rodj
Originally Posted by fbelz
1985 behind the starter.
You mean in front of the starter???
That is the knock sensor
That is in the head
Old Mar 12, 2009 | 10:12 PM
floridamale's Avatar
floridamale
Generally speaking the starter is located at the rear of the motor knock sensor sounds like the ticket.
Old Mar 12, 2009 | 11:02 PM
fbelz's Avatar
fbelz
Default Sensor
Thanks for the help
Will get one tomorrow to get it put back together.
Fred
To Help: Engine Sensor behind the starter.
