Start/No start
I've got a problem with my 93LT1. Yesterday, while leaving a parking lot, the engine just shut off. After a few minutes, it started again but died after about minute or two. (I just sat there and let it idle, for fear it would shut down on me in heavy traffic...)
Anyway, it would start, and then shut off immediately. After a few more tries, you could just tell it wasn't going to fire.
Well, the tow truck arrived, and we couldn't get it on the flatbed due to my recent lowering project, and the fact he didn't have the equip. to handle a lowered car. So, I try to start the car and it fires right up. Let it idle for around 10 minutes, and say WTH and made a run for it.
Got a mile down the road and it shut off again. I wound up pulling it to a safe place and there it sits.
Here's my list of suspects..
Fuel pump
fuel filter
ICM
IAC (It didn't hesitate or stumble, ran fine-then quit)
ECM? Hope not..
The opti/plugs/wires are just a year old...
Ideas???
Thanks!
The problem sounds like a bad ICM (if you lucky). Substitution is the only real way to determine if it is bad. Don’t think testing on a heat related problem will tell you anything reliable.
The ECM could definitely could be the problem. They sure do have a reputation on the 93s causing all sorts of weird problems. However before I point to it I always look to see it there are any other symptoms or strange indications. Many times with a bad ECM multiple symptoms will occur like SES light or any other lights coming on.
Its tough to diagnose it on the road. Finding out if you are loosing the injector pulses or spark is easy in the shop. But if it only happens on the road you might have to come up with a plan to at least determine if you are in the spark or fuel area.
Opti/plugs/wires all 1 yr old...
Update:
Well, I finally got the vette home and I'm starting to look at it now.
So far, the fuel pressure is within limits: 42psi and holding...I can hear the fuel pump priming with no problem..
I'm going to check for spark next....
I'm also going to pull the codes and see what's going on there.
Any/All suggestions welcome...
Bring'em on!
Hey David,
The above got me thinking. I think you said that you did a cut-lid/K&N air filter mod recently. Any chance you could have over oiled the K&N and "greased up" the MAF? If so, some MAF cleaner spray would be a simple fix. Of course nothing is that easy.
Kim
When my ICM died it did exactly what your car is doing. I think there is a way to diagnose with a multimeter whether it is "switching" or whatever it does, but I think you can only accurately diagnose it when the no-start condition is actually going on. If it's failing intermittently, diagnosing it can be tough.
