The transmission yes but I don't see how you would get the block past the motor mounts that are welded in the engine bay and I am not sure with the crank Balancer removed if the front would clear the front cross member.
The engine, trans, and front suspension will drop out together. You will need a lot of clearance.
Not something I would attempt with jack stands.
I can't remember exactly how many bolts held the suspension in but I think it's around 10.
You will have to disconnect\remove your C-beam, drive shaft, brake lines, ABS sensors, engine\trans wiring harness, AC compressor, steering shaft, power steering lines, unbolt the upper control arms. There may be some other stuff I forgot to mention.
sure it can be done, I did an LS1 4th gen f-body like that in my driveway (because that's the only way it comes out). I built a dollie to go under the k-member and trans, got everything almost unbolted set the car down on it, removed the nose so I didn't mess it up and used my engine hoist to lift the front end of the car up high enough. There are some pictures over at thirdgen.org of a guy doing it that way with a 3rd gen. The same can be done with a vette, kinda tricky to do in a driveway though, I wouldn't do it on a c4 like that though since it's easy enough to do it from the top.
c4 was originally designed with bolt-in front crossmember so engine/trans could be ''bottom loaded'' at assembly....recyclers (junkyards) sell the c4 engine/trans as a ''drop-out'' cause they do it faster/ez that way...at home, ''top-out'' has benefits.
btw, correct GM nomenclature is 'engine cradle', not 'crossmember'.
Thanks for all the replies. I thought part of the design to come out the bottom was to allow for fast swaps at the track.
Problem is unlike a conventional engine on cradle setup you have to unbolt the top A arms and shocks to drop it because they attach to the frame , not the cradle
