Help with Distributor Issue
Old Mar 13, 2009 | 08:32 PM
coco1950's Avatar
coco1950
Default Help with Distributor Issue
1989 Covrette Coupe L98
I was running the engine for 10 minutes when the car just shut down. I tried to start it but it would only crank. I repleced the pick-up coil and still no spark. I was going through the check list in the manual and what happen next I could not believe. When I disconnected the tach wire from the distributor the car started right up. Plently of spark and it seams to run fine. If I connect the tach terminal back to the distributor the car won't start.
Does any one know what the problem might be. I tried everthing !!
Thanks for you help.
Old Mar 13, 2009 | 09:15 PM
coco1950's Avatar
coco1950
Never Mine. I found the problem. The tach wire is pinched between the intake manifold upper pipe.
Old Mar 14, 2009 | 12:27 AM
jfb's Avatar
jfb
Congrats, glad for you that you found your problem.
Old Mar 14, 2009 | 08:00 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I was just about to type something similar, until I got to your next post.
My tach wire got pinched between cap and dizzy base. Took a few days before it decided to let me know.
To Help with Distributor Issue
