Quick question about gears:
Old Jan 27, 2002 | 08:58 PM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Default Quick question about gears:
I have a 1992 LT1 with the (awsome) ZF 6-speed transmission, but what gears do I have? I can't be sure what they are at the moment (previous owner may have changed them), how would I tell without pulling the cover and counting ( :U )??? Is there a RPM to speed calculator that I could use?
Old Jan 27, 2002 | 11:24 PM
ShawnZR-1's Avatar
ShawnZR-1
Default Re: Quick question about gears: (92Shawnster)
ttt
Hello? :confused:
Old Jan 28, 2002 | 12:45 AM
91Vette's Avatar
91Vette
The console lid will have the codes for the original axle ratio. I'll leave it to other forum members to help with any other methods to determine rear axle ratio.
Old Jan 28, 2002 | 01:45 AM
ol,RJ's Avatar
ol,RJ
there is a formula.
gear ratio= (rpm x tire dia) divided by (mph x 336)
however that will give you total gear ratio ( the OD in the transmission will affect it) so divide that number by the OD ratio (for a ZF 5th is .75 and 6th is .50 ).
the simplest way to do it is to jack the car up and turn the wheels one turn while counting the rotation of the drive shaft (mark them with tape).
example: if the drive shaft turns 3 and 1/2 turns for one turn of the wheels then it has roughly a 3.50 to 1 rear gear.
Old Jan 28, 2002 | 11:33 AM
ShawnZR-1's Avatar
ShawnZR-1
Default Re: Quick question about gears: (ol,RJ)
Excellent! Great formula. Thank you much! :seeya
Old Jan 29, 2002 | 07:19 AM
ShawnZR-1's Avatar
ShawnZR-1
Oh, RPO: GM3 (3.45). :D
What would the G92 "Performance Axle" be?
Old Jan 29, 2002 | 08:45 AM
GUMPA's Avatar
GUMPA
You can go to 4:10 if you wish............ :yesnod:
To Quick question about gears:
