Help on 87' Vette
Old Jan 28, 2002 | 11:14 AM
LeftysAuto's Avatar
LeftysAuto
Default Help on 87' Vette
Hey I have an 87 L98 that I rebuilt the heads on. I put a compu cam and roller rockers etc etc. It wont idle below 1,000 rpms. I bought a chip figuring it would fix the idleing problem, but it didn't. I think the problem might be the roller rockers are too tight and the valves are closing all the way. I didnt do the head work, a friend of the family did so it could be. Anything else that it could be? What do you all think? :smash:
Old Jan 28, 2002 | 06:11 PM
vader86's Avatar
vader86
Default Re: Help on 87' Vette (LeftysAuto)
is the TPS reading the correct voltage?
Old Jan 28, 2002 | 06:26 PM
C4-Wolf's Avatar
C4-Wolf
Default Re: Help on 87' Vette (vader86)
Exactly!
There is a tech article on the forum about setting your tp sensor.
Go to :Tech Tips >> C4 Related Tech Tips >> How to Adjust your Early C4 TPS and Idle Speed
Old Jan 28, 2002 | 06:29 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you mean the idle won't go below 1,000rpm adjust the IAC and TPS.
If you mean it stalls below 1,000rpm, check all connections and check for vacuum leaks.
Though I did a static adjustment of my roller rockers you might try the dynamic method; it should be quicker. You can either bend pieces of cardboard or use a cardboard box top to catch the oil spatter. I suggest 1/2 turn after the "click" is just gone.
Old Jan 28, 2002 | 11:07 PM
Rick86's Avatar
Rick86
Default Re: Help on 87' Vette (65Z01)
If this is the case do a compression test, it will let you know if the rockers are not adjusted right.
Old Jan 29, 2002 | 09:31 AM
LeftysAuto's Avatar
LeftysAuto
Thanks guys. Ill try that. Yeah once it drops below 1,000 it just dies and i cant get it back. Thanks Ill try it. :cheers:
To Help on 87' Vette
