Shifting Pronlems, PLEASE HELP.
Old Mar 14, 2009 | 03:03 PM
stjs45's Avatar
stjs45
Default Shifting Problem, PLEASE HELP.
Hey there, I been having problems with shifting it into gear. At first it was alittle tuff getting it into first specially when it was cold. Then it got to the point where i had to pull it or push it with both hand. What it does is that from neutral about half way in its normal then half way i reach a "stuck" point and then i have to slam it and then the last half is easy again. Its just in the middle of the shift. IN ALL GEARS. And the worst part is that last night i went to start it pressed the clutch and it cranked but like if i didnt have the clutch in. It shot alittle foward as if i was in gear. This was the first time it has done this. What can be causing this? is this a tranny issue, shifter, or clutch. Thanx
Old Mar 14, 2009 | 04:57 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Check the easy thing first. Your car has a hydraulic clutch, so check to make sure your not low on fluid.
Old Mar 14, 2009 | 06:16 PM
stjs45's Avatar
stjs45
ACTUALLY, as of right now. I have no pressure on my clutch pedal, and CANNOT put it in gear. AT ALL. So im almost sure it has something to do with the clutch. ????????????
Old Mar 14, 2009 | 08:01 PM
derekguzz's Avatar
derekguzz
i had that once there is a container under something up towards the front of your windows in your engine bay. Fill it up and its back to life. I dont know where it is or what its called because my dad did it for me once while i was away. But I think its on the drivers side right by the window. Its under something thow. Sorry for the half AS@ reply
Old Mar 14, 2009 | 08:34 PM
stjs45's Avatar
stjs45
Right is the reservoir for the clutch,right under the computer. Its got the cup gasket inside, I checked and its got fluid. i dont know how high its supposed to be but theres some inside.
To Shifting Pronlems, PLEASE HELP.
