Do You "Burp" Your New Wires??
Old Mar 15, 2009 | 05:12 PM
Donne Trav's Avatar
Donne Trav
Default Do You "Burp" Your New Wires??
Do each of you "burp" your new wires (let possible air out of the "boots") after connection to the Opti and plugs? I mean, Is this absolutely necessary? What are the consequences if the "boots" aren't "burped"?
Some of us have never heard of this procedure before. THANKS
Old Mar 15, 2009 | 05:26 PM
STL94LT1's Avatar
STL94LT1
I've never burped my plug wires and never suffered the consequences of not doing so.
Old Mar 15, 2009 | 05:29 PM
383vett's Avatar
383vett
You only need to burp the wires if they drank more than 6 oz of whatever.
Old Mar 15, 2009 | 05:33 PM
c4cruiser's Avatar
c4cruiser
Coat the inside of the boots with dielectric grease andwhen you push the boot onto the plug or terminal
Guess I've never heard of burping the boots. Never fed them any formula beforehand either.....
Old Mar 15, 2009 | 06:53 PM
skybolt31's Avatar
skybolt31
I put dielectric grease in the boots before installing them and if I wasn't careful, they sometimes would slide back off. It is possible to trap air in there, but if I made sure they snapped in place, none seemed to come off
Old Mar 15, 2009 | 08:37 PM
WW7's Avatar
WW7
WTF??? Please tell me this is a joke, I think I threw up a little.
Old Mar 15, 2009 | 08:50 PM
383vett's Avatar
383vett
Shudda burped after pushing the wires in. It'll happen every time.
Old Mar 15, 2009 | 10:52 PM
DarkBlue88's Avatar
DarkBlue88
From: Charlotte NC, behind someone going 10 under the speed limit
They're gonna burn up or chafe through before it'll matter
Old Mar 16, 2009 | 07:38 AM
Iroc57's Avatar
Iroc57
Learn something new everyday I guess...
Old Mar 16, 2009 | 07:43 AM
78pacer's Avatar
78pacer
Oh boy....you have to be kidding?
Mike
Old Mar 16, 2009 | 07:45 AM
cv67's Avatar
cv67
St. Jude Donor '05
Some guys do it, I never have.
Old Mar 16, 2009 | 10:17 AM
Demonic85's Avatar
Demonic85
dont forget to check your headlight fluid
Old Mar 16, 2009 | 10:27 AM
383vett's Avatar
383vett
For real? There is fluid in the headlights? Do I need a dipstick or do I just stick my finger in the top hole?
Old Mar 16, 2009 | 10:41 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If you can't see the fluid through the glass, the headlight is empty.
Old Mar 16, 2009 | 10:46 AM
AZ86Vette's Avatar
AZ86Vette
Blinker fluid too!!! I was pulled over the other day, cop said i was low on it... You've been warned!!!
Old Mar 16, 2009 | 12:40 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
It has been mentioned in the past to use a spray can extension like on TB cleaner while installing wires on the opti especially if you use di-electric grease. Yes they do get air trapped in them and sometimes pop off. Laugh all you guys want but it also makes it easier to get them to snap into place. You can't always hear or feel when they do.
Old Mar 17, 2009 | 05:21 AM
dan6712cc's Avatar
dan6712cc
How is this "burping" done, do you just squeeze the rubber boot after you make the connection?
To Do You "Burp" Your New Wires??
Old Mar 17, 2009 | 06:35 AM
pianoguy's Avatar
pianoguy
I just squeezed the boots while I was pushing them in to make them not seal against the terminal until they were fully seated.
Old Mar 17, 2009 | 10:30 AM
Redeasysport
If you use di-electric that may or may not work as it does help seal any slight open area. To use the little red straw method just stick it in before you slide the boot on and pull it out after you are sure it is seated. Not real hard to do actually.
Old Mar 17, 2009 | 11:00 AM
MikeC4's Avatar
MikeC4
this is a pretty slick idea. I usually wiggle and twist the boot after it is seated. I always use dielectric and I have seen a boot or two push back out due to the trapped air. This also lets me know that I didn't get the boot seated completely.....with older spark plug wires, you don't always get that reassuring "click" sound, as the as the round end terminal inside the boot strecthes over time and use....
