ball joint dust boots
Old Mar 16, 2009 | 01:39 PM
Demonic85's Avatar
Demonic85
Default ball joint dust boots
I'm having trouble getting these on the ball joints. I'm using Moog parts if that helps. Like all things there's just got to be an easier way to doing this than trying to force it on by hand.
Old Mar 18, 2009 | 02:14 AM
LT1CORVETTE's Avatar
LT1CORVETTE
Have you tried putting a light coat of grease on the inside of the boot and the ball you are sliding it over?
Old Mar 18, 2009 | 04:59 AM
Weav's Vet's Avatar
Weav's Vet
I had the same issue on one I replaced with the Moog. I finally just gave up and keep it full of grease.
Old Mar 18, 2009 | 07:29 AM
dan6712cc's Avatar
dan6712cc
What about trying a heat gun on it, I have mine apart now and am about to try it as I've never been able to slip my Moog dust caps over the ball either.
Old Mar 18, 2009 | 07:37 AM
Weav's Vet's Avatar
Weav's Vet
I'd just give Moog customer service a call. Maybe they have a suggestion or better yet that may be the way it is supposed to be. For a 100.00 a piece you'd think they would work better than this.
Old Mar 18, 2009 | 07:57 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I tried that myself but there appears to be a metal ring inside the bottom of the boot.
Old Mar 18, 2009 | 08:17 AM
Epimax's Avatar
Epimax
Old Mar 18, 2009 | 08:29 AM
Demonic85's Avatar
Demonic85
Thats what I did, I centered the boot over the ball and dropped the knuckle on it and it looks like the weight pushed it down enough to cover it. I will keep checking up on it just in case.
Yes I did try coating the inside with some oil but it didnt help and yeah I'm pretty sure theres a metal ring inside of it too. The uppers were pretty straightforward though, no ring in those. I came to the conclusion that there must be a special tool used to push them on. Thanks for the input.
Old Mar 19, 2009 | 02:36 PM
dan6712cc's Avatar
dan6712cc
Has anyone gotten an answer if these are supposed to slip over the joint or not?
Old Mar 19, 2009 | 04:26 PM
Aardwolf's Avatar
Aardwolf
My new Prothane covers didn't come with metal rings like the stockers had. They simply press over no problem.
To ball joint dust boots
