Won't Start
Old Mar 17, 2009 | 09:24 PM
blown34's Avatar
blown34
Default Won't Start
I've got a 1991 Vet that won't start. Has spark, 48#'s fuel pressure, starts with spray into throttle body; changed ECM from a running car with no change, also replaced fuel pump relay. Can't seem to get the injectors to activate. Anybody got any ideas?
Old Mar 17, 2009 | 10:07 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
you have a shorted one or two injectors that is shutting down the ecu injector driver, ohm check the injectors.. they must be over 12, under that is NG, under 5 is a dead short. Do you know how to check them?
Old Mar 17, 2009 | 11:27 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Injector fuses ??
ECM needs to see a reference signal from dizzy before it will fire the injectors. The signal comes from the module. Bad module could result in no reference signal to ECM.
This info is from my 86 FSM, but may help shed some light.
http://members.shaw.ca/corvette86/En...ButWontRun.pdf
http://members.shaw.ca/corvette86/Ig...System-EST.pdf
Old Mar 18, 2009 | 12:35 AM
blown34's Avatar
blown34
Thanks guys, I appreciate the help; can't wait to try your suggestions tomorrow.
Old Mar 18, 2009 | 01:22 PM
blown34's Avatar
blown34
You were right; #7 injector read 6 ohms and when I left it disconnected the car started. Can you set me up with a set of injectors?
Old Mar 18, 2009 | 01:42 PM
FICINJECTORS
Supporting Vendor
you were right; #7 injector read 6 ohms and when i left it disconnected the car started. Can you set me up with a set of injectors?
call me at 770 888 1662 i will send them right out
jon
To Won't Start
