Rear Bumper Removal?
Old Mar 18, 2009 | 02:11 AM
dragonwarrior88's Avatar
dragonwarrior88
Default Rear Bumper Removal?
How do you remove the rear bumper?
Old Mar 18, 2009 | 02:52 AM
rodj's Avatar
rodj
Bumper or bumper cover?
Need thin arms to get at the top bolts holding the bumper cover to the body work
Just follow the joint line and undo every bolt
101 10mm bolts
Old Mar 18, 2009 | 07:08 AM
JackDidley's Avatar
JackDidley
1/4 drive ratchet, 7 or 8 mm across the top.
Old Mar 18, 2009 | 11:49 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Remove reverse lights & license plate. Reach in through openings and remove two 10 mm nuts on each inboard taillight. Reach in through opening of removed taillight and remove outers. You can see some of the side fasteners through the taillight openings, these are 10 mm. Going by feel, work your way up the sides and across the top removing 8-10 (?) 7mm screws. It's no fun but it's not hard. Now, if you are doing the same as I did, completely replacing the rear cover, then get a sharp razor knife and cut it off following the seam about an inch or so away. This way all the screws are visible!
When you get ready to re-install the cover run a piece of masking tape along the edge of the mounting surface. Then with a pen, mark the location of each and every screw hole. This will make re-assembly MUCH more pleasant than searching blind for them.
Old Mar 18, 2009 | 06:07 PM
dragonwarrior88
ya im about to replace it once i find one lol.
Old Mar 18, 2009 | 08:13 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Get a 7mm boxend ratchet for the ones across the top, much easier.
drop your exhaust and remove wheel well covers to get at 10mm on the sides, my arm is to big to get in through the lights.
Old Jun 29, 2009 | 03:59 PM
techvette's Avatar
techvette
Anyone have some pics of this process?
Old Jun 29, 2009 | 05:43 PM
jeffp1167's Avatar
jeffp1167
if you are replacing the cover with another just cut the old one off then remove bolts holding it on, will save you a good 4 hours of aggravation.
Old Jun 29, 2009 | 07:03 PM
motodog's Avatar
motodog
Thanks guys. i am pulling mine as well and was looking for a way too. Thanks again
Old Jun 29, 2009 | 07:08 PM
jeffp1167's Avatar
jeffp1167
theres a thread on here where a guy cut his bumper cover off look him up saw the thread just a few days ago think he was doing a 1987. ask him where he cut his at.
Old Jun 30, 2009 | 10:51 AM
techvette's Avatar
techvette
Not replacing the bumper, just noticed a small crack I would like to fix. I will post pics later...
To Rear Bumper Removal?
