1993 corvette security system
Old Mar 18, 2009 | 08:11 PM
dmadone's Avatar
dmadone
4th Gear
Default 1993 corvette security system
how do i bypass or reset the security system on my '93 vette.
the security light was flashing off and on then it stopped flashing.when i tried starting it the statrter will not engage.what should i do?
Old Mar 18, 2009 | 08:16 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Did the horn go off? If yes, then unlock door w/key.
If it is the vats, then you need a new key or bypass it(do a search on vats+bypass, lots of posts on that).
Old Mar 18, 2009 | 08:17 PM
dmadone's Avatar
dmadone
4th Gear
no the horn did not activate
Old Mar 18, 2009 | 08:23 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
clean the pellet on the key and try again.
Old Mar 18, 2009 | 08:48 PM
dmadone's Avatar
dmadone
4th Gear
thanks for the info..i tried a couple differnt keys to no solution
Old Mar 18, 2009 | 08:49 PM
dmadone's Avatar
dmadone
4th Gear
is there any other way of getting pass the security system?
Old Mar 18, 2009 | 09:33 PM
93 ragtop's Avatar
93 ragtop
FWIW I have the CATS software, (used for programming the ecm chip) Anyways, in the program, there is a section that has VATS. It can be disabled through the programming.
You may want to post this in the tuning section to get other info. or contact pcmforless and ask them about it. I have used them for my tuning needs and they are first rate. Alvin knows his stuff!!
Old Mar 19, 2009 | 06:13 AM
toptechx6's Avatar
toptechx6
Sounds like the ignition lock cylinder is not reading the key and will need replacement. For a short term fix you should be able to use a VAT's by-pass jumper. Measure the resistance of your existing key pellet to order the correct one.
http://www.ecklers.com/search.asp?ac...searchHistory=
To 1993 corvette security system
