Map Sensor Wiring
Old Jan 28, 2002 | 12:49 PM
Warlock's Avatar
Warlock
Default Map Sensor Wiring
Finally joining the 730 club...
I need a description of which wires are which on the MAP sensor and either a picture or a description like "Looking at the sensor with the vacuum port up and facing away from you" or something similar in case my wires are different colors than yours.
Old Jan 28, 2002 | 01:57 PM
HighHopes85's Avatar
HighHopes85
Default Re: Map Sensor Wiring (Warlock)
If you look closely at the MAP or connector, don't you see an "A, B, C" somewhere on it?
<BLOCKQUOTE>code:<HR><PRE>
PIN DESCRIPTION FACTORY HARNESS COLOR
A Sensor ground Black
B MAP signal Light Green
C 5 volt reference Gray
</PRE>[/QUOTE]
-Matt-
Old Feb 10, 2002 | 01:50 PM
Warlock's Avatar
Warlock
Default Re: Map Sensor Wiring (HighHopes85)
There are no markings on the sensor. On the plug that I got pfrom the auto parts store, they are labeled, BUT the plug will only go on one way because of the slots and the clasp that holds the plug to the sensor is on the OPPOSITE side as the latch it is supposed to go over. Therefore, I dont trust the markings on the plug, because they could be backwards.
Old Feb 10, 2002 | 02:20 PM
HighHopes85
There are about 4 different keyed combinations for the flat 3 wire connector that you are talking about. It might be easier to return that one and buy the correct one. The reason I mention this is look at the IAC motor connector. It is a 4 pin connector but has different keyed slots than the TCC connector comming out of the transmission even though the bodies of the connectors are physically similar.
I looked at mine, but I have my MAP sensor underneath the plenum and the connector has 3 black wires running out of it. I am sorry that I couldn't help you out more. -M-
Old Feb 10, 2002 | 10:23 PM
BOWTYE8's Avatar
BOWTYE8
Looking at the map sensor with the vacum line facing you (say your map sensor is mounted on the firewall and you are looking at it from the front of your car)
the first pin on the left is 5v ref, then center is the MAP sig, and the right is 5v ground.
5v----map---5vgrd
I am not shure how far along you are but you can splice 5v and 5v grd from you TPS sensor the gray should be 5v and the black should be 5v grd.
Then since your maf is now upluged for the 7730 why not take advantage and use the center wire(green) to bring back the map sig to the 7730 ECM.
Look at you center maf pinout for your 165 ecm and then repin that wire to F15 on the 7730.
This helps so you do not have to run and new wires thru your firewall.
One other try, Is you can jumper pin C and pin E at your ESC plug. Leave your ESC unplugged the jump these 2 wires together with a wire on the plug or splice them. This will give you a direct route to the knock sensor which the 7730 needs.
As you will notice your 165 ecm the ESC wire is blue and so it is for the 7730 so repin your blue 165 esc wire to F9 on the 7730. Once again this will give a direct route from F9 on the 7730 to the knock sensor.
Dont forget you need a 90-91 knocker.
Dennis
[Modified by BOWTYE8, 8:25 PM 2/10/2002]
Old Feb 11, 2002 | 02:42 PM
Warlock's Avatar
Warlock
Default Re: Map Sensor Wiring (BOWTYE8)
Thanks...that helped. Actually, I tapped into the MAF 5v, ground, and signal and repinned all to the corresponding locations on the 730. I actually have the 165 knock sensor on the passenger side of the block and the 730 on the driver side and ran a new wire into the cockpit for it. I finished it last night and it started up, so so far so good. Now I need to burn a prom cause the AUJP isn't running for crap...(not like I am suprised). So I switched back to the 165 to drive it back home. (Worked on it at my brother's house.)
Just when I was getting good at burning the 165 proms, I get to start from scratch burning proms for the new computer, yippie! :rolleyes:
Note to any reading this and doing the 165 to 730 swap (or any other for that matter). Got a computer from who knows what car. I got about a foot of the wiring harness for the computer. However, since the harness was for another car and an automatic, not a manual, several of the connections that I needed did not have wires in them. Also there were several connections that I didnt need that had wires. So I had to move some of the wires around in the connectors (push the two tabs on the holder to tak it off, then slided a small screwdriver into the hole above where the connection is to slide the wire out). I would have been much happier if I had done this first instead of having made several connections and finding no wire for the next one I needed. I had to move approximately 5 of them. Also, when you are making the new connections, if the wire coloring of the new wire and old wire dont match, question it and recheck your work. MOST of the new wires are the same color scheme as the old ones. I almost mad a couple mistakes and always rechecking non matching wire saved me a couple times.
To Map Sensor Wiring
