'92 Steering Column Replacement Gremlins
Old Mar 20, 2009 | 11:03 AM
GentleBen's Avatar
GentleBen
Cruise-In 7-8-9-10-11-12 Veteran
Wounded Warrior Escort '11
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Default '92 Steering Column Replacement Gremlins
Recently had the steering column replaced in a '92 coupe with 6-speed manual. However, now the heater/AC fan does not work nor does the Bose radio work, although it lights up. Further, when the operating temp gets above 190, as it goes up the dash lights/flashes "SYS".
What should I be looking for? Is there a fuse or fusible link that could have been compromised by the steering column replacement?
Old Mar 20, 2009 | 03:04 PM
josephf31's Avatar
josephf31
Default There
wouldn't be anything in the column itself or related wiring to cause these systems, but there are any number of wires/connections/etc. in the area around the column which could easily have been disturbed...
Old Mar 20, 2009 | 03:33 PM
toptechx6's Avatar
toptechx6
What did you do to match the key to the original CCM/VAT's ?
To '92 Steering Column Replacement Gremlins
