Never hung out here..
Old Aug 15, 2010 | 10:33 PM
  #101
mnstrlt1's Avatar
mnstrlt1
Been out for alittle while, busy takin' care of business. Glad to see the progress!!!
Old Aug 17, 2010 | 09:51 AM
  #102
rickyrj1's Avatar
rickyrj1
This guy is putting the C4 game to a new level! Now he just needs to sell some of this stuff to us mortals to help pay for his build Great Job!
Old Aug 17, 2010 | 09:33 PM
  #103
COPO's Avatar
COPO
Gonna do what you wanted to do?
What you need
Old Aug 25, 2010 | 08:12 AM
  #104
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I cant wait to see this finished! You have been working on it for a long time and its going to be super sweet in the end.
Old Aug 26, 2010 | 02:26 AM
  #105
mnstrlt1's Avatar
mnstrlt1
What you need
I've been really tied up with my own build, trying to clear out the garage (extra parts). Although, you ARE right I am currently pursuing other career opportunties. I'm hoping for everything to pan out!
I think I can speak on behalf of some of the forum members when I say, "we want it all"!
Old Aug 31, 2010 | 03:50 PM
  #106
LT4POWR's Avatar
LT4POWR
I love this project! Awesome work!
Old Aug 31, 2010 | 10:02 PM
  #107
COPO's Avatar
COPO
Been waiting on the trip to Carlisle to borrow a trans from a friend. Got it bolted up yesterday and it fits. Bad news is that the smallest hydraulic throw out bearing I can find is .18 to long. Went thru a couple forks I had laying around and think I kno of a couple that mite work.
Old Sep 4, 2010 | 10:38 AM
  #108
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Well, you just saved me all kinds of money on any future Viagra purchase I may have had to make....
Absolutely top-notch work!
Old Sep 14, 2010 | 08:03 PM
  #109
COPO's Avatar
COPO
I used a new LS7 clutch that I had laying around. Bought a Fidanza billet FW. Thought I would be saving money down the road with using what I had in front of me. I need about 1/4" to make a hydralic TB work and about the same to swap to a pull style using a fork. I knew it when I bought the FW but I didnt listen to myself. Clutches arent cheep but I want one that will last and eazy on the leg.
Old Sep 16, 2010 | 03:54 AM
  #110
mnstrlt1's Avatar
mnstrlt1
regarding the clutch and transmission adaptor issues, Bill (zfdoc.com) ended up using a bell housing off the F-body LS-x cars and an adaptor plate to merry it to the Zf transmission (his own design using a GM TO bearing). He uses a ZR1 input shaft for the ZF6 (really the only "catch), and is using ALL the standard GM equipment (including GM application clutch assembly- I believe Zo6). Master cylinder is replaced with a larger diameter unit to support the pedal travel, disengagement of clutch assembly.
I'm just suggesting this to others who might be interested or even to the OP.
Old Sep 16, 2010 | 07:50 PM
  #111
COPO's Avatar
COPO
A LS1/2/6 will work fine in the QT BH. I got a lil premature on ordering the LS7 FW. I ordered it on the way home with the motor. It has a raised boss on the FW which extends it out about a inch. At one point it was going to be a budget build thats why I was using the 7 clutch I had laying around. It will get used though on some thing.
I have been talking to some clutch ppl. Didnt know that Spec is just down the road about a hour. Sounds like a road trip to me. Act has the T1SR that looks good.
Old Sep 17, 2010 | 02:38 AM
  #112
BAM92's Avatar
BAM92
What brakes are you running and size rotors? Did you change the master?
Old Sep 17, 2010 | 07:27 PM
  #113
COPO's Avatar
COPO
Wilwoods 6/4 with 14" rotors. I wanted 16" rotors with a lil larger caliper but the money difference was way to much. I can live with these. Either C6 booster or hydroboost.
Old Sep 17, 2010 | 07:58 PM
  #114
grinditout's Avatar
grinditout
Where is the bellhousing from? how about a parts list on this zf to lsx?
Ok, I see the original info, so bump this question.
Tell me about the A/C pump? How is the fit or mod?
Old Sep 18, 2010 | 02:41 PM
  #115
Bowtie8's Avatar
Bowtie8
Been waiting on bigger rotors and they still look small
Would you mind sharing what the Rear Offset and Backspace is
YOu mentioned its a 19x13 already
thanks
JW
Old Sep 19, 2010 | 08:16 PM
  #116
COPO's Avatar
COPO
Dont have a list yet for the ZF but will in a couple weeks. Using a Sanden compressor mounted down low on the pass side. Did have to cut the K member to remove for service.
thanks
JW
It is either 9.3 or 9.5. That one in the pic is the front.
Old Sep 21, 2010 | 05:22 PM
  #117
COPO's Avatar
COPO
Tires mounted and sitting next to a 315 Sumi.
To Never hung out here..
Old Sep 26, 2010 | 11:08 AM
  #118
COPO's Avatar
COPO
Old Sep 26, 2010 | 12:08 PM
  #119
esham's Avatar
esham
Wow! Can you post a pic from the rear of the car?
Old Sep 30, 2010 | 08:13 PM
  #120
COPO's Avatar
COPO
It will be a while before I have any more pics
