Replacing 1990 L98 with 1987 L98.
Old Mar 21, 2009 | 04:23 AM
jdraughn's Avatar
jdraughn
Default Replacing 1990 L98 with 1987 L98.
I am putting an 87 L98 in my 1990 vette to run for a couple of years while I nail down and start building up a 400ci.
The 87 has a MAF while the 1990 utlizes speed density. Can anyone tell me what I will need to swap out from my original engine? The idea is to basically just drop this engine in. I don't want to take it apart - that means you need to start buying seals, gaskets and more.
Does it basically just come down to the intake plenum? Are there any sensors that I need to add or swap?
*Edit - and just so we are clear, the 87 engine is a long block - it's extra long even. It has all brackets, alternator, power steerting, AC, all the smog related pumps, hoses and tubes. I have the wiring harness and ecm too.
Old Mar 21, 2009 | 04:26 AM
jdraughn's Avatar
jdraughn
On this page: http://www.fuelinjection.com/portinj.html
It appears to mention some of this stuff.
Looks like I will need to use the distributor from my 1990 and swap the knock sensors for one - back to looking for more info.
Actually, I reread the text "The EST module, in the distributor and knock sensors are different than the earlier models and must be matched. All hardware components are interchangeable with earlier models."
* So I just need to swap out the EST module or the whole distributor - plus the knock sensors.
* Plug the ninth injector hole
* - still reading
Old Mar 21, 2009 | 08:33 AM
rodj's Avatar
rodj
You need your '90 electrics ;dist and KC
Just leave 9th injector in as plug
Can save swapping plenum out by remote mounting the MAP and running a vac line to it
Old Mar 21, 2009 | 09:56 AM
Demonic85's Avatar
Demonic85
You could just swap intake manifolds and keep your original ECM and wiring since thats pretty much the only difference. MAP vs. MAF.
Old Mar 21, 2009 | 10:33 AM
Iroc57's Avatar
Iroc57
This option requires the least amount of thought
Old Mar 21, 2009 | 10:31 PM
jdraughn's Avatar
jdraughn
Yeah, i am going to swap the intakes, replace the front and rear crank seals and a few other things here and there that dry out from sitting so long.
Old Mar 22, 2009 | 09:26 AM
Iroc57's Avatar
Iroc57
Never hurts to do this. It sounds like you found a perfect short-term answer for you car while you build your motor...congrats
To Replacing 1990 L98 with 1987 L98.
