Engine Smoke
Does it only happen after the car has sat over-night then, once started, only smokes for a short while then stops?
Is the smoke coming out of the muffler(s)?
Jake
West Point ROCKS!
Has it overheated? I would start by checking the coolant level to see if it's low. Have you had to refill the coolant recently? Also check the oil and see if it is a milky color. Depending on how that turns out you can check your coolant system pressure or have an oil sample sent off to test for traces of coolant in the oil. http://www.blackstone-labs.com/ If it was me I would not run it until it's solved.
FYI
Blue smoke from the exhaust is usually oil burned in the cylinders.
Black smoke from the exhasut is usually too much fuel in the cylinder, rich condition.
If not, you can be sure you have a leak. It could be the intake manifold gasket or, more likely, a leaking head gasket. Seems there have been a rash of failed head gaskets lately.
Either way, it'll be time to break out the tools.
Let us know what you find.
Jake
West Point ROCKS!
I would do a compression test on all 8 cylinders. That will end all this guessing on what it might be. Good luck!
Corvette Mike
A coolant system pressure tester is a diagnostic tool.
Same thing a doctor does. The procedure is simple: When you go to the doctor, he asks about your complaint, what you're there for. He then runs some basic tests, like blood pressure, listens to your heart, checks your temperature, pulse, etc. These tests are designed to help in the diagnosis.
Based on the test results and the patient's complaint (symptoms) he knows which avenue to pursue; where to focus his diagnostic effort. If you are complaining about chest pains, he won't start by looking at your feet.
The poster's complaint (symptom) is that he has white smoke coming out of the exhaust. Most of us know to identify white smoke out of the exhaust as being caused by coolant somehow entering the combustion process.
In order for coolant to be present in the combustion process it has to come from the cooling system which, when operating normally, is isolated from the remainder of the engine's systems. So, somehow coolant is leaving its isolated system and entering the combustion process.
The most logical thing to do is to look for a leak somewhere in the cooling system. A leaking hose, leaving a puddle under the car or intake manifold, won't cause smoke out of the exhaust. The leak has to be internal. To check for that you pressurize the coolant system and, if there's a drop in pressure, you then KNOW you have an internal leak.
Now, the problem becomes identifying from where the leak is occurring. There are only a few places that could cause coolant to enter the combustion process.
A cracked head or block, and/or a leaking intake or head gasket are the most common. Absent any other symptom, (like the engine has recently over-heated badly), gasket failure is the most likely cause, so the smart move would be to diagnose for that. Always check the easiest to do and possible cause first.
Doing compression test won't isolate the cause. A low reading on one or more cylinders found in a leak down test could be caused by the piston ring(s), excessive piston to wall, leaking valve(s) and maybe some others I can't think of right now.
BTW, conducting a compression test on one of our engines is easier said than done, do to the cramped engine compartment space. It also requires specialized tools that many of us don't readily have at hand. including a compressor and special fittings. On top of that the results will be inconclusive.
Check using the easiest to do and most probable cause first
Bottom line, conduct tests for the most probable cause first. Tests like checking the oil dip stick for signs of coolant in the oil, draining the oil from the pan, etc. However, the pressure test is by far the easiest, quickest test to do and costs nothing to run.
If not found there, then move on to other diagnostic tests, which we can recommend after getting the pressure holding results.
My money's on a gasket, partially because it's such a common occurrence. It shows up on virtually all the Forums I visit.
Jake
West Point ROCKS!
JMO................. Blown head gaskets are diagnosed with compression tester too.
Blown head gaskets on vettes will smell of coolent, and drip out the pipes.
Valve seals can also be checked by compression test also, as well as rings.
So it's a fairly common occurrence, even in later model engines.
After you located the source and want to repair it yourself, if you need advice on the repair procedure, just post here and we'll help you.
Jake
West Point ROCKS!
Cajun
