slow up top?
. i thought this cam was supposed to run well over 6? any thoughts?
Once an engine passes its RPM of maximum power, the power drops off and you can feel it since the engine no longer pulls as hard.
If your engine has reached it's power peak at 5000, then power flattens out or drops, it could be caused by a number of things. Something as simple as the heads and or intake maxing out in airflow, exhaust unable to flow enough, fuel flow, on and on.
Are you getting any error code(s)?
Jake
I ordered a canned tune from PCM for less and installed that right away.
So it sounds like it's restricted flow from the heads then yeah?
Many engines can rev to redline and higher, but the question is "Is it still making good power up there?"
If you look at any of the dyno graphs found in mag articles and on the internet, you'll see that an engine can continue to rev higher and higher, but the power drops off, sometimes like it's fallen off a table.
Engine keeps revving, but doesn't pull as hard.
The main thing about engines is that in making more power, it becomes an exercise in removing corks to airflow. Once you remove one cork, another one presents itself.
So, when you install a cam that allows more flow, the heads, intake manifold or exhaust can become the next cork, which will limit power. So, you attack the, let's say, the heads; now the intake flow restriction rears its ugly head; then the exhaust, on and on.
It becomes an exercise in cork removal.
If you bolt your car to a chassis dyno, you'll be able to see on a graph just where your power drop off happens and, in many cases, the dyno operator can tell you what needs to be done to correct it.
It could be caused by a number of different things, like fuel flow, knock retard, valve float, etc.
I wish I had a crystal ball and could tell you exactly what's causing your concern, but, alas, . . . .
Sorry I couldn't help more.
Jake
West Point ROCKS!
