4-3 clutch pushrod q
Old Mar 23, 2009 | 02:34 PM
redrose's Avatar
redrose
Default 4-3 clutch pushrod q
would like to know overall length of the oem pushrod that goes between the slave cyl and throw-out fork, rough diameter also... have a pushrod for salie ??...tia, andy
Old Mar 23, 2009 | 09:28 PM
powerpigz-51's Avatar
powerpigz-51
I am unsure of exactly how long my homemade one is.....I do know it was about a half inch longer than the stock one, which would no longer work after I had replaced my clutch assembly. I made mine out of an old 6mm ball driver allen wrench that I cut to size with my bench grinder. I do believe that some wear and slop on the clutch pedal pivots along with the fresh clutch was messing with the geometry of everything not allowing me to push my clutch all the way in. I bled the slave and master every which way except with the car upside down and under water as well as replaced the hydraulics...and this was the fix.
Old Apr 5, 2009 | 12:18 PM
redrose's Avatar
redrose
ttt
To 4-3 clutch pushrod q
