Starting Problems
Old Apr 5, 2009 | 07:32 AM
19vette93's Avatar
19vette93
Cruising
Default Starting Problems
I am hoping you guys can help me with a place to start. I have a 1993 Ruby.
I am having problems re-starting my car after I take it for a short drive. Starting cold, the car starts up, idles and runs great. After I drive it for about 30 min and shut it off and try to re-start it a few minutes later it will not start. It will at first start but if you give it any gas it will die. After doing that a few times it will no longer start, just crank over. Then after about an hour it will start back up and run fine until you shut it off again.
Any suggestions would be appreciated, Thanks, Mike
Last edited by 19vette93; Apr 5, 2009 at 07:34 AM. Reason: switched from general discussion to tech/perf.
Old Apr 5, 2009 | 07:59 AM
toptechx6's Avatar
toptechx6
Checking for fault codes would be my starting point, see the links below
http://www.corvettephotographs.com/c4vettes/codes.htm
http://www.corvetteactioncenter.com/...993:+ECM+Codes
If any DTC's are stored they should give you a direction, but correct diagnosis will require a factory service manual, DTC's identify the circuit that is outside normal parameters, they do NOT indicate a part is bad without additional testing. If there are no codes check for fuel pressure and spark to the plugs when the problem occurs.
Old Apr 5, 2009 | 02:36 PM
JAKE's Avatar
JAKE
Seems like what we call, a Heat Soak issue. I'd first have the ignition module tested because it's the most likely culprit. AutoZone will test yours for free.
Jake
West Point ROCKS!
To Starting Problems
