Negative Battery Cable
Old Mar 23, 2009 | 09:28 PM
Bradster's Avatar
Bradster
3rd Gear
Default Negative Battery Cable
I noticed that my original negative battery cable was disconnected and an aftermarket was used and connected tot he engine block. I believe I have some grounding problems so I bought a new AC Delco negative cable. In addition to the battery connection, there is a short balck wire which I presume gets grounded to the chassis somewhere. There is nothing specific in the repair manauls I use. Any ideas?
Thanks.
Old Mar 23, 2009 | 09:43 PM
tdr1919's Avatar
tdr1919
Thanks.
you will find that grounding issues will plague your very existance! 99% of all the electrical problems with my 86 were not electrical failures, but bad grounding. Also check in the distributor, there is a ground point inside for the elctronic module, clean that up too.
The negative cable should be connected to chassis and there is a ground strap from the engine to chassis ground
Old Mar 23, 2009 | 11:00 PM
Bradster's Avatar
Bradster
3rd Gear
Thanks. ANd the smaller black cable should go where?
Old Mar 24, 2009 | 05:26 AM
toptechx6's Avatar
toptechx6
The factory service manual should show the location on the first page of the ground distribution diagram. If you do not have one a general rule of thumb is that the larger cable connects to the engine block, usually at a bellhousing bolt, the smaller one connects to the chassis or frame. Another alternative would be to find another 84 and inspect it visually, perhaps a forum member who lives nearby will volunteer, good luck.
Old Mar 24, 2009 | 11:53 AM
MarkBychowski's Avatar
MarkBychowski
on my '96, the short cable gets grounded to the frame just to the inboard side of the battery.
Old Mar 24, 2009 | 12:52 PM
Demonic85's Avatar
Demonic85
same for my '85, pretty easy to find.
To Negative Battery Cable
