Crazy timing advance on L98??
This could be the main issue but one question I have is this a new problem that developed over time or has this problem always been present since the rebuild?
His engine builder checked everything (all new performance parts) and still couldn't find the problem. After a week, my friend decided it had to be the new Harmonic balancer. He bought another harmonic balancer from the same manufacturer and noticed that the timing marks were stamp incorrectly on the previous one.
He installed the new harmonic balancer and the engine ran perfect.
another odd thing it did was car engine made a horrible sucking noise almost like a few vacumn cleaners running.
he never got the glowing exhaust or codes btw. His car even passed smog like this and gave no general ideas of the cat being at fault.
maybe not your problem
To make a pump gas car operate with 11 to 1 compression and short cam timing like you have will require some modifications.
-Put a 160 degree T-stat in the car and program the fans for on at 175 off at 165 or add a manual switch to turn them on at will. The engine must be cool to work with 11 to 1 compression. (Don't worry about this being too cool, it will work fine and the engine life will not be reduced. Detonation on the other hand will reduce engine life.)
-Have a custom chip made that reduces your part throttle timing (above 1/3 throttle where you experience the detonation). Have somoone scan the car to see what load values experience detonation and then change those timing tables to eliminate the detonation.
-Also have the part throttle and full throttle knock retard amount changed to allow for more retard in the event that it is still detonating once in a while when the car gets hot or some poor gas is run through it. You mentioned that a fixed 12 degrees has no detonation but has poor performance, well that would be a safe ignition timing set point. In other words have the knock retard table set-up to pull enough timing to get down to 12 degrees of advance so if detonation is experienced it can be eliminated.
I believe with the correct tuning you will be able to eliminate this problem, good luck!
Considering it was knocking and pinging the whole time, this would likely have something to do with it, right? The only codes were for low tps voltage(it was about .53-.54 ) and est (since I previously had it unplugged).
