So Im stumped here, aparently I 1. Dont have all the fittings that came with the kit or 2. The fuel line kit isnt a direct bolt in.
Im thinking a male/male -6A 45 and some sort of female -6A to female whatever the stock fitting is....might work. Anyone else have this problem? I was going to call TPIS but they were already closed.
TPIS 's version is about an 1" long, but will not exactly comp the difference. (your top link is similar to what they make/sell.
When I still used the factory hard lines to the stainless tpis lines:
I had to unbolt the fuel lines (small bracket at the front bottom side of the block) and pull them up silightly and rebend (slighty by hand) the factory hard line to meet the TPIS lines.
Did you also use a 45 with the TPIS fitting?
Originally Posted by rodj
Looks about right.
Yours appears to be a early car ; check return line fitting ;
Is usually 14mm metric O ring ; NOT 16mm
no, I just tweaked the stock lines by hand until they fit. Not sure but a 45* may end up pushing the lines it to far forward.
Cool, I'll look at it again tomorrow. I didnt think id be able to get them up that high ( I already have the bracket loose) but I bet it will end up going together just like yours did.
no problem, glad it helps. Don't fret you'll get them to fit, just a little patience, and some fiddling. Something else I remembered looking at those again, before you tightened the lines up on the intake and at the front make sure the IAC connector fits in there.
